Licence plate holder
Old Nov 24, 2011 | 08:48 AM
dusty-kid's Avatar
dusty-kid
Default Licence plate holder
Hi
I have bought a side mount licence plate holder, but there seems to be no means of fixing it, is there a kit or something which will do the job please
all the best
Old Nov 24, 2011 | 09:46 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
It shoudl slide over the axle.
Drew
Old Nov 24, 2011 | 10:16 AM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by dusty-kid
Hi
all the best
That type is designed to replace a wheel spacer. It is a "fit all" and not a direct bolt on replacement. First you need to make sure it fits your axle size....most newer ones will fit 3/4 and 1 inch. You need to measure the thickness of the bracket and the spacer it is going to replace...chances are they will not be the same. You will have to get an additional spacer or stainless washers to make up the difference. After you have the correct parts, you will have to partially or completely remove the rear axle depending on which way it is installed....Good Luck
Old Nov 24, 2011 | 10:26 AM
2006FLST's Avatar
2006FLST
Tom hit it right on the head. You will need to play around with washers/spacers etc. It will not be direct fit but it is not all that complicated. I will look good when done!
Old Nov 24, 2011 | 03:28 PM
dusty-kid's Avatar
dusty-kid
Ok thank you,
So if it only fits where it touches, then that makes me feel a lot better, I thought this was a Science,
I have taken some pictures showing the inside walls of the axle, and hope the size of the axle can be determined from there,
I measured the size of the Allen key nut , will I need a key or can I use a monkey wrench
The plate holder bracket looks too thick to bolt on to the axle, it looks like it will take up all of the thread
If you make this up as you go along, can I use this washer and rubber bung with a long bolt through the axle bolted to the other side of the axle
I'm sorry I have not found a way to make my pictures big yet,
Attached Thumbnails Licence plate holder-liscence-plate-fixing-003.jpg   Licence plate holder-liscence-plate-fixing-007.jpg   Licence plate holder-liscence-plate-fixing-011.jpg   Licence plate holder-liscence-plate-fixing-012.jpg   Licence plate holder-liscence-plate-fixing-013.jpg
Old Nov 24, 2011 | 04:21 PM
Tom84FXST's Avatar
Tom84FXST
The bracket replaces the spacer marked in the picture
coleslaw140
Oct 9, 2012 08:32 AM
sbryant
Mar 3, 2010 07:38 AM
S1NN3D
May 31, 2009 12:21 AM
frankiefire702
Mar 12, 2009 09:02 AM
99FXST
General Topics/Tech Tips
Jun 23, 2006 06:40 PM
