Beach Bars with Stock Deluxe Riser?
Old Jan 2, 2012 | 10:20 AM
jwilson77's Avatar
jwilson77
Default Beach Bars with Stock Deluxe Riser?
I have searched around and cannot seem to find out if you can use an aftermarket beach bar (Burly, etc.) with the stock Deluxe riser and clamp. I have an '08 Deluxe and want to keep the riser and clamp stock, but want to switch out to a beach bar.
Any advice or photos?
Old Jan 2, 2012 | 10:46 AM
Santo's Avatar
Santo
Yes you can use your stock risers with after market bars but it's gonna look abit strange.
Old Jan 2, 2012 | 10:55 AM
yamensbs's Avatar
yamensbs
My guess is that the stock bars are pretty high for a BB, not only will it make it strange looking, but cold also impact your riding comfort unless you are really tall.
The Stock riser also adds to the pull back if I am not mistaken which will also affect your comfort.
just my 2 cents.
Old Jan 2, 2012 | 11:07 AM
Motown Strag's Avatar
Motown Strag
1.5 inch risers are $35 on ebay and are two bolts. The hardest part is taking off the headlight tins if you have them.
You will also need to swap out the bushings because stock harley bushings are not chrome on top. There is a thread from NC Deluxe that has the part numbers.
Depending on what bars you choose you might be swapping cables and doing a wire extension too so if so you might as well go internal in the wiring.
Old Jan 2, 2012 | 12:11 PM
Benway's Avatar
Benway
just my 2 cents.
I agree with this and the stock risers (4-4 1/2") do have pull back. Not a good look for a fat harley IMHO. Heritage risers are only 2" and straight.
Old Jan 2, 2012 | 04:52 PM
NC D'LUXE's Avatar
NC D'LUXE
As the others have already said, yes, you could use your stock risers (anything possible) but you really aren't going to want to. I think you'd find your controls sitting back around your hip pockets with the stock risers. As Motown said I have a thread that has many of the parts you'll need for the swap that can be found at the following link, Burly Beach Bars Installed
I spent a little more on the riser and cover, but also as already pointed out, you can find a much less expensive 1.5" riser setup to go with. I just felt if I was going to spend over a grand upgrading my bars (I upgraded all my controls to chrome etc), I'd shell out another benjamin to get a smooth cover because in the grand scheme it wasn't much more in the end.
Good luck with whichever you decide, but I'd strongly recommend swapping out the stock riser. And don't forget to post some pics when you get your install finished up.
Old Jan 2, 2012 | 09:19 PM
elbohead's Avatar
elbohead
I'm thinking of going with beach bars while my Deluxe is in storage for the winter. I really like what's possible as seen in the pictures, especially the internal wiring. NC, I had my doubts about leaving the bags on but your results put that to rest. Looks great! Using your set up, can I still use my HD quick detach windshield? I'll keep an eye on this thread. Thanks.
Old Jan 2, 2012 | 09:54 PM
NC D'LUXE's Avatar
NC D'LUXE
Yes, I still have the quick detachable windshield too and it is still functional. With the bags off though, I need to get her lowered and need a shotgun setup.
jokr
Mar 15, 2010 02:45 PM
bulkhead
Mar 31, 2008 11:23 AM
pic824
Jan 28, 2008 07:06 PM
abrailman
Jan 23, 2008 07:40 AM
deluxe
Mar 30, 2007 08:55 PM
