modifying my windscreen
Old Jan 12, 2012 | 06:58 PM
jneubig's Avatar
jneubig
Originally Posted by cmosentine
Thanks for the replies. This may seem kind of a dense question, but does the headlight get moved up when the aux lights are installed? Based on the responses above, they imply the headlight gets moved up as that is the only way the windscreen could possible interfere with the headlamp.
The headlamp stays right where it is. The aux lamp bracket attaches using the same mounting points as the windshield only (4 bolts).
Old Jan 12, 2012 | 07:39 PM
tunaman's Avatar
tunaman
That is my point. I own one of these.
" ... Detachable King-Size Windshield for FL SoftailŽ Models
Windshield kit includes all the hardware required to fit FLSTC, FLSTF and FLSTN models without auxiliary lamps. ..."
The question is: Can these be modified to work with the lights?
Well, if that is the case, and given that the headlight doesn't move and the aux light bar mounts below the headlight, then it is likely the width of the mount that is the issue. With the aux lighting, there is a pair of brackets installed on the sides of the nacelle, which widens the mount point. It isn't a problem for the removable shields as the spacers are already installed and just replaced with narrower spacers. However, with the fixed shield I'd guess there isn't a way to mount the brackets on the outside of the shield mounts, hence the problem. It these guesses are correct, then I'd say it would be difficult to modify your mount to accommodate and that the mount framework would have to be replaced, at very least.
Again, this is mostly guess-work on my part without photos. I'll post up some pics of mine so you can see the parts in question if you'd like?
Roger
Old Jan 12, 2012 | 09:31 PM
Big H's Avatar
Big H
Originally Posted by jneubig
The windshield for aux lights is slightly wider at the mount points to accommodate the bracket holding the lights. That's the reason for the two part numbers. You can use the wider one (Heritage style) on a non aux light model by shimming out the rubber mounts, but the non will not fit with aux lights.
This is your answer.
aviscomi
Apr 27, 2019 01:26 PM
EasyGT
Nov 18, 2013 09:52 AM
KingCripps
Jan 6, 2010 08:42 AM
kpb46
Apr 16, 2008 10:49 PM
rick
Feb 1, 2007 04:40 PM
