Best advice is to a.) read as much as you can to educate yourself; and b.) if you're going to have someone do the work, get their input on what you want.
There's a whole lot to this simple decision, and if you make a good one you will be happy; if you don't, you won't, and will be spending a bunch of money down the line to compensate.
As previously stated, your head will spin with all of the opinions you will get here. And most of those will be based on the personal decision that they made, based on the singular experience they've had, and not a relevant comparison of the effects of different choices. You will, however, find that the SE 204 is a very popular choice and it seems that many are very happy with them.
If you start looking at dyno charts DO NOT pay attention to the max HP and TQ numbers.
Pay attention to when the TQ comes on strong (RPM) and when it drops off.
If you get some huge cam that creates huge TQ but doesn't come on until 3000 and drops off at 5k yet you want it at 2k to about 3.5k you are going to be disappointed.
That sudden burst at 3k will feel cool but another cam may have had you way down the road sooner.
With that said I picked a HQ 500 for my otherwise stock 96 and have been happy with it.
I'm looking for more but I think it was the right cam for a stock 96.
Now I want a big bore kit and a different cam. may even try a big bore with this HQ 500 as Head Quarters thinks it will do well in a 103.
The vendor I am dealing with does not do screaming eagle so if I went the 204 I would have to find and Andrews compatible cam.
Keep in mind my 26H is in a Electra Glide Classic... pulls good... on a lighter bike like DJL suggested maybe a Andrews 48. Hey anything you pick will be better than stock... you *** dyno will be happy...
Keep in mind my 26H is in a Electra Glide standard... pulls good... on a lighter bike like DJL suggested maybe a Andrews 48. Hey anything you pick will be better than stock... you *** dyno will be happy...
The Andrews 48H is a very good option just check compatibility with your machine.
As stated, picking a cam can be very confusing. Different overall tire sizes affect the final gearing. Different air intakes affect flow into the engine. Air temperature, density, and and humidity skew the readings. Different dynos...and so on. You get the point.
Just to be different, I tried the new Lunati .510 cams in my 88-inch Fat Boy. Made good solid midrange values. Wanted to test different air intakes and tried a tubular forward facing air intake against my Screaming Eagle backing plate with an open filter. The bottom end picked up an additional 3-1/2 lb-ft of torque from 2000 until 4400 rpm.
This is where I learned to keep U Intake close under 38* if Ur wanting a good low, mid Tq cam without BB kit and Head work..for a lighter bike and solo rider will work good.
The heavier the bike load the lower number to look for.
SO I go to the Dealer Sat. and ask some general questions on cams. I tell him I'm thinking of the 204, 255. He gives me a look and says he has not put any 204's in a 96 and 255 is more for the 103 the only one he's recommending for the 96 is the 254E. I haven't looked at the 254E yet. I want the idle lope of the 204 and good low end, I usually don't shift past 4000. Thoughts and opionions needed !!!
