Se 204
Old Jan 18, 2012 | 08:07 PM
tmilo1000's Avatar
tmilo1000
Default Se 204
Decided to change cams while the tensioner was being changed. Decided on the SE 204. The part number in the HD catalog is 25464-06. I got a pretty good deal on the cams.
The question I have is the box says "fits '06 later Dyna Models and '07 later softail and touring", will this cam work with a '03 Fatboy 88 inch motor?
Old Jan 18, 2012 | 08:52 PM
Fierofly's Avatar
Fierofly
According to the research I've done you need p/n 25149-00. The reason I know this is because I've been looking for the cams you bought 25464-06 on E-Bay. The only ones I've found are the ones that fit yours. PM me if you decide to sell.
Old Jan 19, 2012 | 11:27 AM
tmilo1000's Avatar
tmilo1000
I am not doubting your research, I found the same thing on eBay. I do know that HD has been known to change part numbers.
Is this still true if you are upgrading to the SE hydraulic tensioner and oil pump? My local dealer even said the p/n 25464-06 were the correct cams. Are the cams different or has the part number just been changed?
Old Jan 19, 2012 | 11:40 AM
KumaRide's Avatar
KumaRide
204's in an 88" is not a good match. Maybe with a 4 degree advance key. A good option is the Andrews tensioner kit and an "N" style cam like 21N or 26N.
Old Jan 19, 2012 | 11:44 AM
djl's Avatar
djl
The -06 part number suffix tells you that the the part will not fit '06 and later models. That PN will not fit your '03. Furtheremore, they won't work if you ugrade to the SE hydraulic tensioner/roller chain setup. The won't work with the hybird cam plate because it is designed for the 25149-00 cams and they won't work with a full on conversion to the later OEM setup because the rear cam journals are the wrong size. Conversion cams are required and H-D doesn't offer any conversion cams.
Sell to fierofly before he finds a set somewhere and you lose a ready buyer.
Old Jan 19, 2012 | 01:42 PM
TheTroupe's Avatar
TheTroupe
DJL is correct the 25149-00 is what you want, you will also need a 17045-99D Cam service gasket kit. While you're in there replace the inner cam bearings.
And the SE 204 is an excellent choice for your 88.
Old Jan 19, 2012 | 01:59 PM
tmilo1000's Avatar
tmilo1000
Thanks for the input. Maybe next year I can go to a 95" motor. Right now I want a little more umph on the low end and mid range.
Old Jan 19, 2012 | 02:57 PM
Sash302's Avatar
Sash302
I am looking at Dave mackie TC-510 cams little more aggressive than se204, will work good stock and BB.
Old Jan 19, 2012 | 03:01 PM
TheTroupe's Avatar
TheTroupe
It's a riding style thing, the TC-510 won't give you as much low and midrage ummph, but it will most likely deliver better peak HP numbers.
Old Jan 19, 2012 | 10:43 PM
KumaRide's Avatar
KumaRide
Do some research regarding 204's in 88". Let me kick start you so to speak... lol
https://www.hdforums.com/forum/7763049-post11.html
204's in a 95" is better.
Also, you cant go wrong with a 2n1 for low to mid increase.
scasey
May 22, 2011 08:32 AM
PaulD
Jan 20, 2011 09:32 PM
2005 Roadking
Oct 24, 2010 08:57 AM
bigbean78
Jul 18, 2009 05:13 AM
d.dimperio
Exhaust System Topics
23
Mar 17, 2008 01:29 AM
