Raked Triple Trees
Old Jan 19, 2012 | 06:20 PM
pococj's Avatar
pococj
Originally Posted by Sgt_Jim
would make it harder to take slow corners, no? i have never taken his train out, so i dont know
The trail would be decreased by running the raked trees so it should handle more quickly.
5 degrees would be about the max I'd personally feel comfortable with. I've lived through more than one tank-slapper over the years. It ain't fun.
Harleycharlie1992 has 6 degree trees, but also 3" over forks. The extended forks cause an effective frame rake increase and that would help limit the decrease in trail caused by the raked trees alone.
The raked cups (see Tom84FXST post) and the raked trees would be the best way to get 6 to 8 degrees with the least amount of possible handling problems caused by too little trail.
Old Jan 19, 2012 | 08:49 PM
Ash16's Avatar
Ash16
I always go with what pococj says because he hasn't failed me yet and from his picture he must be an old dude and old dudes know a lot. When you're ready to make your fallaway adjustments follow his instructions. They're a lot easier and work perfectly.
Old Jan 19, 2012 | 09:15 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
pococ is so old that when he was born, the dead sea was just sick!! (thanks dicky!)
Old Jan 19, 2012 | 09:58 PM
Iron lHorse's Avatar
Iron lHorse
Originally Posted by harleycharlie1992
have 6*'s on my deuce with 3 over tubes, have no ill handling problems whatsoever, yes 32 stock and the trees make 38* take a look at the sig pic
Not to change the sub , But were did you get 3''over fork tubes . I always see them in even #s Also need to see much larger pic of your bike .
Old Jan 19, 2012 | 10:10 PM
story808's Avatar
story808
Same here 3* raked trees... I wouldn't go 5 with my setup.
Old Jan 20, 2012 | 03:52 AM
Nocturnalnature's Avatar
Nocturnalnature
I'd go with trees too. All of the raked cups I have seen do not work with the factory steering stem lock.
Old Jan 20, 2012 | 04:59 AM
jreichart's Avatar
jreichart
Most aftermarket trees won't work with the factory steering stem lock either, at least none of the Pro Ones do. That was certainly not a main concern for me though.
Old Jan 20, 2012 | 05:19 AM
DixinTex's Avatar
DixinTex
ive been where your at..wanting just a little more rake..the old scool fix we did in the days gone by...the old pan models used adjustable rake trees on the sidecar models..these trees use leg caps that pivot on upper tree. lower tree swings on axis..swing the lower tree out ..little more rake..lowers the front for sidecar...swing back for solo riding to stock rake.. jp cycles sells the whole kit in the geezer catalogue but you'll need to get them chromed. do ya research and be sure they fit..am savin up for me a set for my 05 nt
Old Jan 20, 2012 | 09:57 AM
08Nighttrain's Avatar
08Nighttrain
Thanks for all the great info. If I go anymore than 5* would that not make my front end start getting too low without getting oversized forks to compensate. I do see that I shoud gain about half to 3/4 of an inch when I switch trees since new uppers have tubew screw into them not through them like factory trees do. Living in florida I do go on the interstates alot going to daytona and key west etc. So I need it to handle well at highway plus speeds. I am dumb enough that I will sarifice comfort for looks but not safety.
Old Jan 20, 2012 | 11:29 AM
harleycharlie1992
forking by frank, he will make any length for you highest quality stuff, go to my garage larger pics there
