swingarm bag install question
Old Jan 21, 2012 | 08:39 AM
RANGER73's Avatar
RANGER73
Originally Posted by 08rock
I also used the plate system but I substituted smoke tinted plexiglass 3/16 thick for aluminum diamond plate works great
Keep an eye on the plexy glass, it'll dry out and crack. And you don't want your bag in your drive belt. JMO
Old Jan 21, 2012 | 10:47 AM
PureDeath's Avatar
PureDeath
Originally Posted by Kowan
Buckles inside.
Not sure what you mean by an extra strap. Mine came with the upper two riveted inside and the two lower straps loose.
I have mine mounted on diamond plate with a three point mounting using the belt guard mount points.
+1, it's the only way to go!
Old Jan 21, 2012 | 10:49 AM
PureDeath's Avatar
PureDeath
Originally Posted by Ash16
Yeah the diamond plate was too expensive at Lowes so I just bought a piece of 12x18 16ga weld steel.
That's what I did, painted it black and it's all good!
Old Jan 21, 2012 | 11:58 AM
keywestwillie's Avatar
keywestwillie
Cool
I wonder why no one has turned these backing plates into a business venture?
Old Jan 21, 2012 | 12:44 PM
Kowan's Avatar
Kowan
I was parked at the dealer and asked why I didn't make a kit for the solo bag/plate mount.
I told the guy it wasn't tough to make one up. I even told him I used WARG's blog writeup as a starting point for mine.
http://www.chasinwhitelines.blogspot.com/
Old Jan 21, 2012 | 02:02 PM
Sgt_Jim's Avatar
Sgt_Jim
i used a 1/16" sheet of stainless steel.. pain in the *** to cut through and grind, but quite solid when all the pieces were put together.. now i've gotta take the coupler nuts off my bike and do something about them to keep them from rusting/oxidizing/or not blending in..so i'll probably just blacken them out like i did with the steel plates.
Old Jan 21, 2012 | 02:10 PM
Fierofly's Avatar
Fierofly
7075 aluminum on the INSIDE to help distribute the load on the leather held on by 2ea 1/4 wide zipties at each of the 4 points
Old Jan 21, 2012 | 05:52 PM
Woweh's Avatar
Woweh
Talking
Originally Posted by frozensoul
never installed one so i know this is a dumb question but do you feed the straps through the slots so the buckles are inside or outside the bag? and what about all the extra strap? again i know its a stupid question but never having put one on i wasnt sure. thanks for any help. i bought the leatherworks 5 inch wide bag.
I installed with the buckles on the inside of the bag and cranked down on it, found it was loose after a week, not because of the buckle but the leather stretched a bit with the vibration. Tightened it up again but this time I put black cable ties through, together with the straps. Hasn't moved or loosened in a year. You have to use the black ones though, they are more durable and they make the bike EVEN faster...lol
Old Jan 21, 2012 | 10:08 PM
frozensoul's Avatar
frozensoul
i hear ya woweh, think my rocker feels so fast cause of all the black zip ties on the wiring,lol!!!!!!
Old Jan 21, 2012 | 10:12 PM
Ash16's Avatar
Ash16
Black is the fastest color. Just go and ask all of the guys in the Night Train pic thread.
