Turn signal mounting brackets
Old Feb 12, 2012 | 10:01 AM
jharanin's Avatar
jharanin
Default Turn signal mounting brackets
May have to go a different direction on mounting my turn signals because of clearance. I was thinking of moving them to the swing arm if necessary. I've Googled "turn signal mounting brackets" and haven't found anything that I like. I'm looking for some vendors other than JP Cycle that might have a selection of universal brackets...any help is appreciated.
Old Feb 12, 2012 | 10:28 AM
jreichart's Avatar
jreichart
I got rid of my rear bullets and used a couple of 2" long led strips from custom dynamics that I mounted on top of the swing arm. I have since removed them, but they were on for a couple years with no issues. Not the most visible solution, but it hid them pretty well, and total cost was around $40.
Old Feb 12, 2012 | 10:53 AM
2DAKERB's Avatar
2DAKERB
What kind of lights?
Made my own. I'm a cheap guy though.
Took a thin strip of metal, drilled three holes, two for the strut mount bolts and one for the light.
Couple of pics. Looking at the pics now, I realize I have to hide the wire a little better.
Attached Thumbnails Turn signal mounting brackets-2-12-12-001.jpg   Turn signal mounting brackets-2-12-12-002.jpg
Old Feb 12, 2012 | 04:45 PM
jharanin's Avatar
jharanin
I like the idea...I think I've decided to drill the strut and mount the signals through the strut.
Old Feb 13, 2012 | 06:36 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Have you considered replacing the factory bullets with the kind that fit the end of the fender strut?
They use LED's so they are brighter than their small size might indicate.
The down side is they are not very cheap and you'll probably need to add in an equalizer to the circuit to make the flashers work properly.
Here's one to give you an idea what they look like.
If you look around I'm sure there are others from other makers.
http://www.silvereagleharley.com/All...ductId=7725157
1stHD_95FXDWG
Electrical/Lighting/Alarm
Feb 28, 2014 04:05 PM
brettnbama
Oct 4, 2012 06:25 PM
Marky the Sparky
Nov 15, 2010 02:52 PM
CRZYLGZZ
May 17, 2010 05:24 AM
Radalack17
Jan 29, 2009 12:43 PM
