Battery issues maybe more?
Not sure if it's true but they were Harley Service Techniains
I always thought that as long as the two systems were 12 volts it didn't matter. But when I jump a bike off of a car i always hook the Negatives to the frame and not directly to the battery. Just always heard to do it that way on a bike???????
You shouldn't start your bike in the colder weather for short periods of time, like to charge the battery.
The reason why is that the engine heats up a bit but doesn't stay at operating temp long enough to burn up the condensation that builds up in the motor from the engine heating and cooling down.
Normally the condensation is turned to steam by the hot oil and pumped out the crankcase vents to the carb and then burnt up in the motor during normal driving.
After a couple of these short period running sessions you will have moisture build up in the oil that will have that milky look to it.
(Kinda like it looks on a cars dipstick when it has a blown head gasket. (water in the oil)
It will start to form first where you can see it, on the top inside of the dipstick.
I know this because it happened to my brothers bike when he took it to work all last winter. It was only a five to seven minute ride to his job each way. It drove us crazy trying to figure out how water got into the motor since it is not water cooled and he didn't power wash it.
After alot of research on the internet and confirming it with a trusted mechanic, we got the answer which is what I just described.
DO NOT tell them you jumped the bike with the car running.. just tell them you have a problem with the battery going dead..
up until here recently cars charge all the time regardless of whether the eng is accel or decel.. now hybrids are another story.. they charge on decel only.
i know honda is experimenting with a clutch drive alt so it only charges at higher rpm's.. it won't be long and we'll be getting dumb *** complaints of dim lights and low blower speeds at idle..
if the car is running when you connect the bike the voltage will dip for a moment and then try to stabilize and go slightly high for a moment. The moment of low voltage will increase amp draw which can cause damage(like that blown bulb). The moment of high voltage can also cause damage (like stater or regulator damage). That's why a bike doesn't do full charge till the rpm go up. It won't have the low voltage issues at idle and have to rev the engine itself to assist regulation. The regulator on a bike just keeps the voltage down which is easier
