Battery issues maybe more?
With these small batteries, when it is discharged to the point that it won't turn the motor over, it really needs to be slow charged at 2 amps or less back to full capacity. Charging it faster (higher amperage) can cause a diminished capacity. At normal running rpm, the bikes charging system provides significantly more than 2 amps.
A cars charging system charges at the same voltage as a Harley. The battery actually acts as a large resistor in the system that keeps the voltage under 14v. Disconnecting a battery cable while an engine is running will cause the charging system voltage to jump up as high as 17v. Jumping a Harley from a car that is running will NOT cause any bulbs to burn out.
It is possible for a cars alternator (if it's a high output alternator) to cause damage to a bike's charging system if you rev the car's motor while jumping a bike from a car. As long as the car is only idling, it is not producing high enough output to do any damage.
Cars still charge all the time, regardless of accel or decel. As far as hybrids go, you are confusing the battery in the engine compartment (the one that powers the ignition, lights, and starter motor) with the battery bank that powers the electric drive. The regular automotive battery in the engine compartment is always kept fully charged. The battery bank for the electric drive is charged differently. Hybrids have a special braking system that converts kinetic energy (inertia) into to electricity to charge that battery bank. That's not the only way the battery bank gets charged though. It also gets charged on demand by the charging system.
no i wasn't confusing the hybrid battery with the basic battery. i replaced my fair share of both on civics. when i think hybrid, i think about and assume(my fault) that everyone thinks about the large battery pack in the rear of the vehicle. The basic battery on a hybrid is charged through a DC-DC converter which is controlled by another computer separate from the eng PCM.. there is no alternator or starter on a hybrid. The Stator and rotor, ( which is very similiar to the charging system on the harleys) is sandwiched between the eng and transmission provides torque for accel and power to recharge the main hybrid battery on decel. its a simple yet complicated system.
replacing the SE compensator on my bike a few weeks back reminded me of the special tool i use for replacing rotors on the civic hybrids. you definitely need a special tool on those to pull the rotor.. they have so much magnetic pull on them, its physically impossible to pull it out without the tool.. and you damm well don't want to try and install it without the tool either.. you will loose a finger or two.
Went to the dealership this morning and they checked out the charging system. The battery apparently is starting to go but is still passing all of the factory tests. The starter and voltage regulator are just fine. They advised me to keep the bike on the tender/charger when not in use and if there are any more problems to bring it back in. My warentee will still cover the battery till august so lets just hope it dies before then and I dont have to pay for a new one. I hate having to half *** something and just wait for it to fail but unless i just want to up and buy a new battery I dont have a choice. I am just glad there were no other problems found. oh, and the running light in the tail light decided to work just fine again lol. Luckily the eliminator is in the mail and I dont have to worry about bulbs here soon.
Then only partially charge it with the Battery Tender, and ride it around, then let it sit a while, then do it all over again.
The warrenty doesn't obligate you to keep the battery on a Tender otherwise the company would have to supply one with each bike purchased.
The battery should only last a few more of those sessions! lol
