sissy bar problems
Old Mar 7, 2012 | 03:39 AM
2000FiveOh's Avatar
2000FiveOh
Best bet is to either drill, dremel, or grind the heads off the bolts. With a dremel or small grinder you should be able to get enough of the head gone to pop off the rest without screwing up your chrome. You should be able to pull them out from the inside along with the metal pieces they screw in to. Then take it to your vise and grab the remaining length of bolt. With a little persuasion or heat you should be able to spin them out. It's always a bitch doing it on the bike.
durtyburt
Sep 1, 2017 06:30 AM
dobeman21
Nov 22, 2012 04:59 AM
TxCowboy
Apr 27, 2012 11:53 AM
scripture187
Nov 2, 2009 05:44 PM
saltlick
Sep 14, 2006 06:38 PM
