Combination Analog Speedometer/Tachometer ?
Old Oct 16, 2012 | 05:23 PM
GinsengSullivan's Avatar
GinsengSullivan
Originally Posted by Yancey
UPDATE UPDATE UPDATE !!!!
TAKE NOTES ! I talked with a very knowledgeable female parts clerk at Ray Price HD in Raleigh, NC. Upon describing the problem I was having with installing the 70900072 Speedo/Tach on an 06 Deluxe, She agreed the the unit not work and in fact there is another part number that will work on 04 through 10 Softail. It will display MP/H only, NOT KM/H.
The following part number installs, downloads data, and works as described on 04-10 Deluxe and some other models.
PART NUMBER: 70900070A
Thanks for the update Yancey..
Old Oct 26, 2012 | 12:09 PM
tech7734's Avatar
tech7734
Just got a 2013 Softail Heritage. Any idea if it's plug and play ???
Old Mar 12, 2017 | 01:16 PM
Custardglide's Avatar
Custardglide
I know this thread is almost 5 years old but I have just acquired a 2011 heritage Softail as a second bike and a good buddy has a brand new analogue speedo/tach part number 70900072A in the box which is for Softails 04-10, Does anyone know why this wont work on a 11 before I get it?? TIA
Old Aug 23, 2019 | 09:05 AM
Pat Hamer's Avatar
Pat Hamer
Weird thing, I have an 05 road king, and speedo shorted out after washing it. I bought this same tach, but the model # ends with B instead of A. Same thing except for there is no KPH on MPH. I followed the install and data link to a T, and when I would ignition I'd get a NO CAL in the LCD, and then that would go away, and it was replaced with NO SPD. It would not transfer the odometer to the new odometer. I'm thinking that if your speedo stopped working, replacing it with this type of Speedo will not work due to the inability to transfer odometer reading of a broken speedo to the new speedometer. I can't find anyone with an answer to this.
I thought this might be an issue, as the old speedo was as if it wasn't there because IT WAS BROKEN (insert Sam Kinison Tirade). Our shop service guy in Folsom checked with the mechanic, and "it's okay, just follow the directions." Engine switch on, Data Link plugged in, no go! I had the old speedo out, and was tapping it and banging it slightly, and I saw LED partially show numbers, they would immediately dim if I stopped squeezing the old gauge. Thinking the ecm possibly sensed the old speedo after doing the Fonz bang and tap on the old speedo, which seemed to allow some juice into it, so I did the transfer procedure again, and something did change this time as it just went to NO CAL, without going to NO SPD.
I'm assuming NO SPD means it isn't sensing a speedo. Well It stopped that, and the NO CAL shows. There is a red light blinking, but then after a bit the red light goes solid and stays on. But still it did not do the conversion. The trouble shooting guide for this particular NO CAL says, normal function, but ads as long as "percentage and ok" show, which they don't. I went ahead and plugged the new speedo into the consul to see if something happened, and the new speedo lit up beautifully, but with NO CAL or something I forget. But no odometer transfer. I'm wondering if I should ride it and go through that 31 mph countdown the document spells out.
I'm going back down to get a speed sensor. Apparently, it could be that issue if the signal lights don't cancel, for one sign. With the bike just leaning on the stand, it doesn't cancel. Somebody said I had to at least lean it or move the steering for it to cancel, which I haven't done. So, I'll check for cancellation leaning and turning the bike. With all the forums out there only about 4 of these issues are on the net, and none of those who had the problem explained how they solved it. These speedo combo's don't work if your replacing a broken one. They should explain this, as there is no refund for them. They seem to only work if you are upgrading. I need to get the odometer reading back, as I'm selling. Any ideas?
Kbrodee1966
Jul 2, 2018 09:16 PM
El Chiguete
EVO
Jul 5, 2017 05:52 PM
gi_king_ken
Apr 16, 2012 05:39 AM
schwingding
Sep 15, 2011 06:26 AM
JBA111
Jan 15, 2008 01:00 PM
