2012 Deluxe Wheel & Samson Install Questions
Wheel Question:
Using the stock spacers the wheel goes on fine but once you tighten down the caliper, it goes to crap. When tightened down the caliper is "pulling" the wheel to it creating drag which creates a headache.
Comparing the stock wheel to the DNA Mammoth, the stock wheel bearing on the right side is recessed in the hub. The bearing on the DNA is flush with the hub.
Would it be possible to pull the bearings and axle sleeve out of the stock wheel and put them in the DNA? If not, what would the best option be?
Edit* - After some research it looks like getting a custom spacer will be the best option.
Samson Question:
Is the shift linkage supposed to "sway"? The best way I can think to explain it is that it sways like a hammock. Where the shift linkage bends upwards, the actual bend is resting on the inner primary. Moving the shifter with my hand, it shifts freely but it doesn't seem right.
Simple shot at the beginning of the night with the wheels mocked up.
As far as the wheel goes. A member had a very recent post (within the past few days)with his front DNA wheel. I cant remember who it was or under what thread. If I remember correctly, I don't think his bearings were seated correctly or pressed all the way in.
He measured from length between the recessed bearing and edge of the hub. He's going to machine down the spacer based off of this measurement and hopefully that'll get us there.
But then I guess we can lay some blame on HD for continually changing things up to try and force folks to buy their custom wheels. I wouldn't want to be a manufacturer trying to keep up with HD's changes but then again I guess that's what pay aftermarket vendors big money to have folks on staff to stay on top of the ever changing tweaks HD pulls out of the hat.
Don't forget to put your rear rotor on.
