I think there's actually video tutorials online that show you step by step how to change things out.. i know there's a 59 minute long one from S&S on how to change your cams that has a ton of detail to it.. and i think i've seen one on how to change the top end, but i can't find it now.. needless to say, if you've got the space and the equipment, you could probably do it yourself, with the exception of the heads (porting i mean, if you're doing that)..those i'd send out to someone with the proper equipment to do
A long as you have a manual & take your time, it's pretty simple. Just did 98"bb cams & cam plate, adjustable push rods. Seems to run great. First time I've done it.
Well, you don't but if you change CAMs then you may want to bump up the Compression depending on which CAM you choose.
In any event, depending on what your really going for you should plan it out well and do it right the first time so you are not tearing it down again anytime too soon.
Mike
NY
agree'd.. heads are where you really gain the benefits of doing all that work
