It also may be gunked up and not going back down enough to change into third or higher. Clean it up and check for adjustment as stated.
I'd highly recommend you follow this path before you see the dealer. You weren't cleaning the engine with any solvents the night prior where you? I ask because the same senario happened first time I cleaned the engine with SS100. Some dripped down where the linkage runs into the transmission and it wouldn't shift up past second. Try getting in the area with WD-40 and work out Good luck!
