Clutch adjustment
Old Apr 4, 2012 | 01:11 PM
JohnFlorida's Avatar
JohnFlorida
dont need a torque wrench
soft 02's Avatar
soft 02
Originally Posted by RaymondTM
Thanks, good idea about changing the screws out.
So, what the torque on the adjusting screw nut? Very important to use a torque wrench, or no?
12-17 foot lb is hand cinched. I dont use the tourqe wrench for it but thats just me.
Old Apr 4, 2012 | 01:40 PM
nikonf8's Avatar
nikonf8
Default derby cover
Harley shop tells you to change the gasket every time. i go in there and i see them with one screw left at 12 oclock the cover swung up and tighten there to keep it out of the way then they drop it and put in the rest of the screws . check the paper work and there is a charge for a new gasket . i just happen to be in the shop one day and seen this with my own eyes
Old Apr 4, 2012 | 01:55 PM
FUBAR55's Avatar
FUBAR55
Thanks, everyone.
Is it necessary to use a torque wrench on the adjusting screw nut, do you think? The spec is 172 - 120 in.-lbs.
I never have. I just tighten it till my elbow breaks.
I do however torque the derby screws.
Old Apr 4, 2012 | 02:56 PM
Gman in NC's Avatar
Gman in NC
I've had my derby cover off three times so far. No problems. I don't torque the T-27 screws. Just put them in and check after a ride or two.
Old Apr 4, 2012 | 03:44 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Question is whether ya gonna run a dime or a nickle adjustment at the lever. Have no idea why ya adjusted the clutch pack, only you know that. I replace that gasket with aftermarket beaded silicone as well as the inspection plate, Torque is snug then gradual titen crisscrossed. How in the hell could you mistake the correct torx is a lil bewildering too...grinz
Old Apr 4, 2012 | 03:52 PM
OkieNiteTrain's Avatar
OkieNiteTrain
Man, I have seen that a million times myself at different shops. I had a sales route for 25 years and sold to those dealers and walked around in shops every week in different cities. There are a lot of charges for things they don't use. Not saying every wrench is like that, but I have seen my share of them.
Old Apr 4, 2012 | 04:33 PM
Bikenator's Avatar
Bikenator
From: in a trailer next to a ditch in South Florida
Inch pounds = foot pounds X 12. (ft lbs x 12) e.g. 10 ft lbs = 120 inch lbs
Foot pounds = inch pounds divided by 12 (ft lbs/12) e.g. 120 inch lbs = 10 ft lbs
tylerfj24
May 28, 2019 11:19 PM
BinIdaho
29
Mar 29, 2010 08:22 AM
The Dane
Nov 1, 2009 11:15 AM
dgreer169
Jul 11, 2009 06:50 PM
Cranky CJ
Jun 4, 2008 12:20 AM
