Just flashed my Rocker with a Power Vision I got from Fuel Moto, and now the bike pops like crazy on decel. Going to call Fuel Moto and talk to them about it, but since I won't be able to get ahold of them until tomorrow wanted to hear others results. I thought that a tuner would help reduce popping, not increase it.
should be an easy fix. As far as I remember, you'll need to add a little fuel in the first couple columns under throttle position. I'm sure they'll be able to get you all setup.
OMG what do you think you're doing! You're letting out all of the best secrets.
Only 20 threads? I'd be surprised if it's only 20...
The map you flashed in is an approximation of the A/F mixture(s) for a cross section of bikes with similar set-up. This is like my V&H FuelPak. The FP instructions give you some advice on one setting to "help" with popping. I'm sure FuelMoto can provide better help as they don't seem to be secretive about which settings to tweak to dial in your specific set-up. Or...put it on a dyno.
