PCIII Numbers
Old Jan 11, 2008 | 07:24 PM
08KING's Avatar
08KING
Default PCIII Numbers
Just installed the PC III and took it out for a spin,,huge difference in throttle response and power, just a little help if you can.
I have posted my map from Jamie, I still am getting some popping on decel, not every time though.
Fuel Moto is closed and I was hoping for some wisdom on what numbers I can play this weekend to help the popping go away.
000000000
000000000
050000000
054000000
0910900000
015121570000
017131011-4000
01514812-4000
08799-5000
0881011-5-200
0812118-5-113
001415140553
001019182683
001313140134
000782034
000371046
00008-1168
000250058
00004-2-236
0000-4-4-126
0000-11-6-803
0000-7-9-7-21
0000-12-12-10-6-2
0000-17-12-10-21
000000000
Thanks for any help.
Old Jan 12, 2008 | 01:28 AM
sifularson's Avatar
sifularson
Default RE: PCIII Numbers
I had the same issue. Random pops on decel. Hard to duplicate every time. Posted my problem and several members recommended that I add numbers to the firstcolumn. I put 10 in the 0 column from 1000 RPMs up. So, when you are at 0 throttle there is 10% more fuel than the stock ECM. This eliminated the issue. No more popping.
You may have to add more. A couple guys told me to add up to 25 if I needed to. 10 worked so I didn't need to add more.
I'm no expert. I'm sure someone who knows more will post. Anyone????
Steve L.
Old Jan 12, 2008 | 07:49 AM
08KING's Avatar
08KING
I will give that a try, thank you.
Old Jan 12, 2008 | 07:58 AM
wnogood's Avatar
wnogood
Just a word of advice, if the pop gets worse with that added fuel, suspect a leak at the exhaust flange etc.....more fuel will make it really sound off!
nogood o~`o
Old Jan 13, 2008 | 09:38 AM
08KING's Avatar
08KING
Tightened everything down, bumped it up and the popping was gone, thanks for the help
jluda
Jun 21, 2014 07:17 PM
paguy
Jul 24, 2011 05:01 PM
theredscout
Aug 31, 2009 06:37 AM
2007fltr
13
Jun 9, 2008 11:53 AM
ardbark
May 27, 2008 03:01 PM
