Tuning Question..HELLLPPPP
Thanks!
Some options may be 1) contact fuelmoto let them know your set up and ask for map recomendations. 2) ask the forum members for map recomendations 3) find a shop that understands and can adjust your pc.
As a long shot try running something like Marvel mystery oil through the gas, really. If by chance it is carbon build or a dirty injector this will help clean.
Thanks!
Typically, a hesitation is caused by a lack of fuel when needed. By adding some fuel on the "low end", there's a good chance you'll solve your problem.
1) Connect your PCIII / Hook up your bike to a PC or laptop.
2) Open Power commander software, and note the first column.
3) You need to raise the values a bit (about 5%) in the first two columns (0 and 5), from rows 1000 - 2000rpm. That range is typically where your throttle is, when your problem seems to occur.
Also, while the bike hooked up, give a few revs, and note where the bike "pops" or backfires. Give a little more fuel in those areas as well.
Fir example....A slight rev might show that you get some popping at 0% throttle @ 2500 rpms. It's at that point, where you add some fuel.
Try it. See what happens, but make sure you SAVE you current map, before making any changes.
