master cylinder bubbling problem bleeding brakes
Old Apr 5, 2012 | 06:50 PM
ilnighttrain06's Avatar
ilnighttrain06
Default master cylinder bubbling problem bleeding brakes
Okay so I have been doing a bunch of work on my 06 night train and when i was all done i took it for a spin but the brakes didn't feel right. They had very little stopping power. so i opened the cylinders and found out they were low on fluid. I went and rented a vacuum pump from advanced auto parts and tried the following:
1. remove lid of master cylinder
2. attach hose to pump and nipple on caliper
3. pump to 10 hg
4. open valve on caliper
It seemed to pump most of the fluid out and i think I might have got some air in the lines.
The strange thing is that the whole time i was pumping and draining the fluid, the master cylinder was bubbling and spilling out fluid. This didnt seem to add up. Any ideas why this will happen?
I tried to add more fluid and pump it through but now I can't get any pressure on the hand lever and the pump doesn't seem to pull any through. it just bubbles. Did I damage something in the master cylinder? Thanks in advance.
Old Apr 5, 2012 | 06:56 PM
Tampa Fatboy's Avatar
Tampa Fatboy
I'm old skewl, partial filled glass with brake fluid and a hose into it, work the lever titenin the nipple before releasing it and repeatin the process til no more bubbles.
Old Apr 5, 2012 | 07:32 PM
ghostrider69's Avatar
ghostrider69
Years ago I had one hellavu time getting all of the air out of the system. I had gotten them to where I had brakes but they still felt spongy. So what I did was top off the rear reservoir and placed the lids back on them but did not tighten the lid down. I unbolted the rear caliper and laid it on the floor so that the caliper was lower than the reservoir. On the front I topped off the reservoir and placed the lid back on leaving the lid loose and turned the handle bars to the left. Turning the bars to the left helps maintain vertical path for the air bubbles to follow all the way back into the reservoir. Same holds true for the removing the rear caliper and placing it below the reservoir. I let the bike sit overnight. Came out the next morning and the brakes were perfect.
Old Apr 5, 2012 | 07:36 PM
ilnighttrain06
So what is causing the master cylinder to bubble and spill under the vacuum pressure?
Old Apr 5, 2012 | 08:52 PM
Tee&Vee's Avatar
Tee&Vee
I believe that is called the "gravity method". And this only costs a bottle of new fluid and a zip tie.
Old Apr 5, 2012 | 09:46 PM
RANGER73's Avatar
RANGER73
Bad vac pump or connected backwards? pumping air in not out?
Old Apr 5, 2012 | 10:19 PM
ilnighttrain06
That is what I thought. Now I have sure in the lines from letting the mc get too low. I pump the brake lever and no resistance builds. Any suggestions?
Old Apr 5, 2012 | 10:20 PM
ilnighttrain06
Air in the lines I meant. The auto correct in my phone screwed that up
das56170
EVO
24
Oct 30, 2023 07:53 PM
cj741126
Sep 6, 2014 04:02 PM
Jshipley90
Oct 20, 2013 09:37 AM
KDagostino
Wheels/Tires
Feb 15, 2013 08:31 AM
sdkimes
May 15, 2008 11:34 AM
