I have a 2005 TC88, I just had a 98 kit put in with cams. I was told that 98 is the biggest the stock cylinders can be bored to. I had this done at a shop so I cant answer many technical questions. It pulls like a beast.
build a bullet proof 95'' with gear drive cams, and get the headwork done and high compression pistons (pump gas still) you won't be disapointed.
the 96'' motor as you know it is the same bore as the TC88 it's just stroked. cubic inches go up by bore and stroke, and I reccomend a stock bottom end unless you wanna dump a few mor $K into trued and welded crank.
I was going to just do cams but going to a 98 big bore was only 590 more...why wouldnt a guy take the cheap hp? You are going to save money since you dont have to buy a tuner so why not.
2 things you didn't mention, budget and are you paying a mechanic. I put the SE 95" and an Andrews 26 cam in mine with a decking and cc'ing of the heads. Got me 80 HP and 98 ft/lb torque and did the work myself, except for the headwork, for around $1000. In hindsight, I would do what Lundee recommends, 98" boring your cylinders,Andrews 37 cam and stage II headwork, although I'm very happy with the results of my build. I have a carb as well and you can keep the stock carb with a re-jetting. If you go with gear-driven cams, you have to check crank runout before you order the cams. Crank runout cannot exceed .003". Otherwise, you can keep the chain drive and depending on mileage, replace the tensioners and use a Baisley LMR-002 oil pressure spring or upgrade your cam plate altogether. I used Hillside to do my headwork and I would HIGHLY recommend them for any machining and advice. If you go over 180 psi on the CCP, have compression releases installed in the heads. Some guys will use 190 as the magic number for CR's but I have 183 psi and the starter barks from time to time. Good luck.
