Help with some EVO info, please
Old Apr 17, 2012 | 02:18 PM
autoteched's Avatar
autoteched
Stage II
Default Help with some EVO info, please
Hey everyone!
I've been searching the site for some answers to questions I have on the EVO engine. I've been off of two wheels for nearly 20 years, and my last HD was a mid-80s Shovel. I'd appreciate your help.
The FXSTC I own now has an S&S "E" model carb, and aftermarket pipes. I think there may be a modified cam installed based on the idle quality of the engine. There is also an HD high performance ignition module installed and another mysterious black box wired in under the seat. When riding at warm temperatures (75 and up), the bike will give a bit of spark knock under moderate acceleration. I've tried higher octane fuel, and if anything it adds to the problem.
I'm running 20w50 Harley oil in it, but I'm thinking I should switch over to Amsoil to help the engine run cooler. I'm wondering if the engine is just running a bit too hot. Should I get an oil tank stick with temp gauge to see how hot the oil is getting? What is a good range?
I really appreciate your help.
Old Apr 17, 2012 | 02:26 PM
Scuba10jdl's Avatar
Scuba10jdl
Sounds like you may need to retard the ignition timing a bit if you're getting spark knock on high octane.
Old Apr 17, 2012 | 02:31 PM
autoteched's Avatar
autoteched
Stage II
I'm wondering if, with the mileage it has on it, the combustion chambers are carboned up. In the auto world, I'd try running some GM Top End cleaner through it.
Any methods you guys have had good luck with?
Old Apr 17, 2012 | 09:11 PM
Doug S's Avatar
Doug S
If it's pinging and your fuel is good then timing is a place to check but not just the timing adjustment. EVO's use a VOES switch which acts similar to an older car's vacumn advance and it can be defective, have a vacumn leak or bad wiring.
That extra black box could be something for the lights, funny but my bike came with one in front of the battery, I disconnected it, reconected the stock wiring and everything worked, still does 4 years later.
The oil subject has been beaten to death around here but just use 20-50 dino oil, EVO's run pretty cool compaired to twinkies. My bike came with one of those temp/dipsticks, it's a good thing to check when you get off the bike, kind of lets you know if something changes. Mine runs 170-180 and slightly higher on a real hot summer day.
To get rid of carbon, get one of those plant mister spray bottles and with the engine running, spray the water mist in the carb. Keep the motor going and repeat the misting, black filth will come out the pipes if it is carboned up. Becareful, if it starts puking black junk it will go all over the place and it's hard to get off some things if it is allowed to dry...
Hope this helps some
Doug
Old Apr 18, 2012 | 10:16 AM
oct1949's Avatar
oct1949
Just found in here as stated above, most Evo's temps are Usually around 180-190. So U don't really need the SYN oils cause U wont have the high heat like the TC's have.
SYN Oils alone won't cool her down very much anyway.
If U got her used why not get a full Elc check and tune up to get her running good.
Right now Ur just trouble shooting, nothing wrong with that, but if U get her checked out and all the bad or old parts that needs replaced or close to needing replaced with new ones and get a good tune then U'll know shes in really good shape and have a trouble free ride for yrs to come.
Just me, but I'd rather spend $$$ and know all is well rather than break down somewhere on the road because of another failed old part.
keyskruiser
EVO
16
Mar 23, 2016 12:12 PM
Scuba10jdl
Feb 29, 2012 12:56 PM
Doug S
EVO
17
Jan 10, 2010 10:02 AM
JRK5892
Custom Models
11
May 5, 2009 09:45 AM
ssls6
EVO
11
May 5, 2007 06:05 PM
