Just purchased Covington 3 degree trees for my 01 Fatboy. I was a little nervous spending the money after all the negative comments on high speed wobble. I would really appreciate more riding experiences from those of you who have actually used raked trees. My bike is currently lowered 2" in the rear only - adding mild 3 degree rake, and not planning to add any length to front tubes - hoping trees and stock tubes will drop front end slightly and even out suspension front to back. Think I will have handling issues? Indy thinks I should be fine.
I'm trying to weed out a wee wobble at high speeds, my '08 ****htrain has a rear lowering kit, and 5* rake triple trees. At around 120km/hr I start getting front wheel shopping cart feel, I need this top go away, I have steering dampener installed and it seems to help a bit. I was wondering if lowering the front end with a drop in spring kit would help bring this back steady, I was blaiming my Damn Dirty Apes but the more I read into rake and trail I think this is the cause.......so will lowering front end fix it? Anyone? Anyone? Bueller Beuller?
I've had folks tell me never to go over 3* in raked trees (not frame) unless it's on a trike. 3* is considered the limit you can safely push the trail reduction and not have the shopping cart effect.
Did you put your specs into a trail calculator to see what your trail would (or is) be ?
[QUOTE=R_W_B;9942860]I've had folks tell me never to go over 3* in raked trees (not frame) unless it's on a trike. 3* is considered the limit you can safely push the trail reduction and not have the shopping cart effect.
I was told this as well by a guy who rakes bikes as well as other stuff for a living but I've just noticed this is a dusted off post from 2 months ago so the OP is probably long gone.
Dusted off or not I'm in for the input. Deuce has a stock trail of 5"s so I'm thinking a 3* or 4* raked tree with a 2" drop in the rear will bring me closer to a 3" trail, which should handle well at speed or slow turns. Anyone see some flaw(s) in my plan ?
