air pressure ??
Old Apr 20, 2012 | 01:14 AM
brettnbama's Avatar
brettnbama
Default air pressure ??
When you guys change wheels or even just brands of tires, how do you determine what air pressure to run? Do you still go off of the factory recommendation or what? I know how I do it for cages, with the chalk line, but can't imagine that would work on a bike tire because of the shape....
Old Apr 20, 2012 | 01:23 AM
tunaman's Avatar
tunaman
The rating on the tire? I figure it is there for a reason, but that could just be me.
Roger
Old Apr 20, 2012 | 02:41 AM
brettnbama's Avatar
brettnbama
Roger
I know that is an option, but I wanted to see if that is what you guys go off of or not. Especially since the bikes have different weights, etc.
Old Apr 20, 2012 | 03:32 AM
jreichart's Avatar
jreichart
I know metzler gives recommended tire pressures on their website. The ones stamped on the tires themselves are max pressure at max load, so I don't use that to determine running pressure. Though if I was completely in the dark on what to run, I'd probably take the max pressures minus a couple psi and see how they felt.
Old Apr 20, 2012 | 04:39 AM
Blk and Chrome's Avatar
Blk and Chrome
I have Avons and run them at 45psi Most are a little more than the factory pressure
Old Apr 20, 2012 | 05:19 AM
challutz's Avatar
challutz
Iusually research the manufacturers website, using the max as a starting point since my bikes pretty heavy, always seems to feel pretty good right there too.
Old Apr 20, 2012 | 05:46 AM
brettnbama's Avatar
brettnbama
thanks.....
Old Apr 20, 2012 | 03:47 PM
poppavein's Avatar
poppavein
Go by what the tire manufacturer recommends. Another rule of thumb is that the tire pressure should be about 10% higher when warmed up from cold.
I've been feeling the temperature with my hand. It's important that the rubber gets warmed up enough so it will stick, but not overheat so that it gets slippery (and would wear out faster).
Old Jan 24, 2020 | 09:38 AM
rozemab's Avatar
rozemab
I used this on my FLHRC with wire wheels. The head rotates to change the angle between the handle and the head. Works quite well and minimizes the frustration dealing with the rear tire.
Old Jan 29, 2020 | 12:47 AM
AKL1's Avatar
AKL1
Under all circumstances, the tire pressure depends on the riding weight and the tire dimensions.
The pressure stated on the tire itself, is a recommended max pressure.
No matter what tire you put on, foolow the instructions from the bike manufacturer. From there, it´s possible to adjust a little both ways according to air- and road temperature, riding style and other stuff.
107inMO
Wheels/Tires
Jun 19, 2019 04:21 AM
S.D.M.F
Oct 14, 2012 04:07 PM
Topspin
Aug 23, 2010 08:36 AM
anubisss
Dec 11, 2008 10:28 PM
sleepneagle
Aug 12, 2006 11:23 AM
