Air pressure?
Old Jun 18, 2019 | 08:31 PM
107inMO's Avatar
107inMO
Default Air pressure?
I tried searching but I'm not good at it! Optimal tire pressure for longest mileage? 2018 ultra limited. Stock tires.
Old Jun 18, 2019 | 08:48 PM
dfwhockey17's Avatar
dfwhockey17
Spec is 36F/40R, with Dunlops I see much better wear on my customers bikes setting them at 38F/42R...The bigger part of the equation is checking them often as under inflated tires will get hot and wear quicker...
FWIW, I run my Avons at 40-42F and 44-46R. Different tires like different pressures...
Old Jun 18, 2019 | 08:57 PM
TriGeezer's Avatar
TriGeezer
Whatever HD recommends. Sure, pump them up for better mileage, and you’ll have a dime sized contact patch. The best tire pressure is a compromise between ride quality, handling, traction, tire life, and others. The best to know that are the HD engineers, so go with what HD recommends. Keep checking your pressure and balance.
Anyone that says use what’s on the sidewalls is grossly uninformed.
Old Jun 18, 2019 | 08:58 PM
107inMO's Avatar
107inMO
I check air daily. I have FOBO TPMS. I have been running 40 and 42 but wasn't sure what has been the popular settings? Naturally when asking a dealer they will only tell you what's in the book.
Old Jun 19, 2019 | 04:21 AM
guido4198's Avatar
guido4198
I've found the recommended tire pressures to be much higher than my own personal "compromise" numbers. I start there, then lower pressures until I get what I want.
On my bike at least...(1985 FXRS) I haven't noticed any significant loss of mileage on my tires.
brettnbama
Jan 29, 2020 12:47 AM
jaknb
Jul 17, 2017 03:33 PM
iride1
Mar 18, 2012 05:01 PM
mopardave
The General Motorcycle Forum
70
Dec 28, 2008 10:49 PM
sleepneagle
Aug 12, 2006 11:23 AM
