I am trying to find a map that would work on a 2005 Fxsti-- s/e a/c --Vance and hines straightshots (slip-ons) and a PCIIIusb.
[/align]I have looked all maps over onPC web site and can not find one that goes on this set up....so anyHELP would be greatly appreciated ... thanks again
[/align]Mac
sounds like it's dumping way too much fuel in there.
How about MAP #805-201 for 2006 Harley Davidson Softail Screamin Eagle II slip-ons Screamin Eagle air filter Stock ECM.
I think the 805-201 should be a good starting map. If you still have pops email Power Commander Tech dept. Tell them what setup you are running. They will email you back with the map you should be using and will help you make adjustments through emails if needed. Quick response and more than willing to help you. Got my bike running super after one adjustment. Email address below:
Tried Map 805-194..805-201 ..it Puffed and Farted.....then started messing around with different maps and found that Map M810-031 works pretty dam good..need to get DYNOED sometime in the future...Harley dealer has dyno but will not work with PCIII just SERT.....go figure[/align]if you know of any problems that will arise with me using this Map please let me know. Thanks[/align]
