84 Softail starter problem
Old May 16, 2012 | 10:24 PM
MMCHD's Avatar
MMCHD
Stage IV
Default 84 Softail starter problem
I recently purchased a 84 Softail Evo motor kick and electric start. It has happened several times in the short time i've owned it that when i hit the electric start button and let off the starter still keeps turning the engine.The only way i've figured out to make it stop other than unhooking the battery cable is to push down on the kick starter,it seems to disengauge the starter. I have put in a new battery and also a new starter solenoid and also a new starter relay,,,nothing has seemed to help. Any ideas? Thanks in advance
Old May 16, 2012 | 11:50 PM
byersmtrco's Avatar
byersmtrco
You need a new bendex (starter drive)
My 84 Shovel had the same starter setup. Hitachi junk.
But it did that. That thing ate starters like Cheerio's.
Old May 17, 2012 | 06:21 AM
Tom84FXST's Avatar
Tom84FXST
Most likely with the problem you describe, you have a worn or bent starter drive lever...might take a look a the return spring in the solenoid while you have it apart.
http://www.jpcycles.com/product/6000450
Old May 17, 2012 | 08:06 AM
MMCHD's Avatar
MMCHD
Stage IV
Thanks You both refer to a part as a starter drive and a starter drive lever are you talking about the same part or is that 2 different parts? Also if i buy a new starter is that part in the starter or is it an external part that i buy seperate ?
BubbaFLMC
Shovelhead
May 6, 2019 07:47 PM
garystaven88
Electrical/Lighting/Alarm
Oct 25, 2015 11:39 AM
hardheaded
Shovelhead
Jul 1, 2013 12:11 AM
pd76
EVO
May 7, 2012 07:22 PM
sunup420
EVO
Feb 7, 2010 11:58 AM
