06 heritage running bad
Old Jul 7, 2012 | 06:08 PM
shaneh1993's Avatar
shaneh1993
1st Gear
Default 06 heritage running bad
was riding in hills at high elevation and started running bad .Got back down but still runs bad. Changed fuel and plugs but no change . Need help
Old Jul 8, 2012 | 01:22 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
Go with the simple, cheap things first.
Check your battery cables (and ground to frame connection).
Check to see that your battery is fully charged.
Anything more serious than this may involve a mechanic
to check your cam chain tensioners and/or intake manifold gaskets.
I would suggest that you not drive this bike until you can have it looked at.
Old Jul 8, 2012 | 01:40 PM
fcsallan's Avatar
fcsallan
is there anything else that is common when it gives you grief? Lower fuel perhaps, hotter weather? Altitude can make a difference but with a computer controlled system it should not be noticeable.
Old Jul 11, 2012 | 11:30 AM
shaneh1993's Avatar
shaneh1993
1st Gear
also i just discovered that the heritage is not recieving any spark to the front cyclinder. i changed the ignition coil, but still no change :/ any ideas?
Stormin Norman
Aug 30, 2015 07:36 PM
98harleyman
Oct 24, 2014 07:10 PM
Ratbike_Mike
Aug 20, 2014 11:30 AM
oldryder
May 29, 2010 01:22 PM
Mark Boshart
Exhaust System Topics
Mar 18, 2010 06:37 PM
