A question for Blackline owner
Old Apr 22, 2013 | 06:12 AM
24v's Avatar
24v
Originally Posted by caducus
I realize this is a little dated, but I'm looking to put this seat on a denim slim and was told by Danny Gray that the suction cups wouldn't work. Did you mod your seat or bike? Or does the suction just work well enough that it't not really an issue?
Works fine on the denim paint. No need to mod anything.
Old Apr 24, 2013 | 12:33 PM
caducus's Avatar
caducus
2nd Gear
Seeing as you have this setup, is there any chance you can help me out with what I posted here:
https://www.hdforums.com/forum/softa...lp-me-out.html
Old Apr 24, 2013 | 04:46 PM
24v's Avatar
24v
I saw that, but I have no clue how to accurately draw that from the bike. Maybe try to find someone with the Harley removable bar. That is what I have, and the angle of it seems to match the seat well enough.
Old Apr 25, 2013 | 12:12 AM
caducus's Avatar
caducus
2nd Gear
I'm just looking for good enough. Maybe I can pull it from a picture of the bar. Which bar do you have?
Old Apr 25, 2013 | 06:04 AM
24v's Avatar
24v
Look at post #6 in this thread. That is the closest image I have showing that angle. I have the 1 piece quick release Harley bar.
Old Apr 30, 2013 | 12:18 PM
caducus's Avatar
caducus
2nd Gear
I have a question about the hardware on that seat?
My bike didn't come with a HD pillion. There's a plastic cap where the screw would go. The Danny Gray didn't come with hardware-- it's assumed you'll use the original stuff.
What all is holding the seat down? Is it just a screw, or is there a screw/small washer/nut/etc assembly that I need to put together.
The tab on the pillion seems to be way up high off the fender so I wondered if there was some sort of spacer/washer between it and the seat when screwed down.
Just trying to figure out what hardware I need to pick up.
Old Apr 30, 2013 | 04:34 PM
24v's Avatar
24v
It is just a thumb screw, or any fastener you want to use that will fit. I can't remember the size, but I want to say it is 1/4"-20? When you tighten the screw it will pull the tab down in place.
It is the same size as the one that currently holds your front seat down. There should be an insert in the fender for it to thread into?
socialoutcast
Mar 10, 2014 03:49 PM
cobrahd1999
Nov 27, 2011 03:27 PM
m1crazy
Jul 13, 2011 08:12 PM
_Flea_
Mean City Cycles
Jul 1, 2009 01:43 PM
srm148
May 16, 2008 09:44 AM
