Wobble/front fork ?
Old Jul 11, 2012 | 07:14 PM
kozy22's Avatar
kozy22
Default Wobble/front fork ?
So tonigh I'm riding and I think I feel a wobble. It's more of an up and down not side to side, and it might have just been the road and then my head.
Anyway could it be the dyna beads?
Or maybe the forks? I think I might have a broken fork seal, but waiting until fall to have it looked at. But could that be the reason.
Also I started looking at the forks, and noticed that there is a hole in the bottom left fork (rotor side) it doesn't feel threaded but is there supposed to be a bolt or anything there?
Old Jul 11, 2012 | 07:34 PM
Blk and Chrome's Avatar
Blk and Chrome
Sounds like the neck bearings need to be adjusted
Old Jul 12, 2012 | 03:16 PM
kozy22's Avatar
kozy22
Ok any input on the forks? Is that hole always there or did something fall out
Old Jul 12, 2012 | 03:35 PM
fdb2007's Avatar
fdb2007
my '10 Heritage has a hole at the bottom of the left fork--1/2-5/8" diameter
Old Jul 12, 2012 | 04:12 PM
beasleyiv's Avatar
beasleyiv
The hole is so you can get the damper bolt out when you're disassembling the forks.
Old Jul 13, 2012 | 07:28 AM
bikefxds's Avatar
bikefxds
I agree with Blk and Chrome...you've probably got stearing head bearing adjustment problems. My indy showed me how to do mine...the manual has you going way to far to get to them. The actual adjuster nut is under that big chrome fork stem bolt up top. The real trick though is to loosen the two fork pinch bolts on the fork bracket. Stealership said they adjusted mine but it still shook like a pole dancer. My indy did it the right way and I can ride it no hands from Florida to Minnesota!
JWCFatboy
Dec 8, 2018 12:30 PM
Scott Skarda
May 14, 2018 01:24 PM
tattoofever
May 21, 2013 07:18 AM
fenderzig
Oct 26, 2012 02:50 PM
ONEEYE05FLSTC
Jul 27, 2012 08:39 AM
