back fire during start
Old Jul 14, 2012 | 11:21 PM
AlmostFatBoy's Avatar
AlmostFatBoy
Stage II
Default back fire during start
my 98 fatboy backfires during start. i sprayed carb cleaner and when I tried to start, fire came out of carb and a loud backfire from exhaust. prior to this i adjusted my clutch. I don't know if this has something to do with the backfire
Old Jul 14, 2012 | 11:36 PM
ghostrider69's Avatar
ghostrider69
Did you have the key on when you adjusted the clutch? If not then your clutch ignition timing is 180 degrees out and is causing the backfire. Why would you spray carb cleaner in the carb. How much did you spray? You should give the carb cleaner time to evaporate before trying to crank the bike.
Old Jul 15, 2012 | 01:54 PM
oct1949's Avatar
oct1949
I don't know wither to Laugh or feel sorry for that response..
Old Jul 15, 2012 | 02:09 PM
ghostrider69
Just laugh. It's good for the soul.
Old Jul 15, 2012 | 02:10 PM
Mark_H's Avatar
Mark_H
"clutch ignition timing is 180 degrees out and is causing the backfire"
Huh...never would have thought of that....
Old Jul 15, 2012 | 02:18 PM
RANGER73's Avatar
RANGER73
It's the carb cleaner igniting.
Old Jul 15, 2012 | 02:42 PM
piperbob's Avatar
piperbob
Me neither.
I would have checked the tires for correct air pressure first.
Bob
97 Heritage
Old Jul 15, 2012 | 08:27 PM
AlmostFatBoy
Stage II
i let the bike sit overnight to dry carb, still not starting.
Old Jul 16, 2012 | 02:03 PM
oct1949's Avatar
oct1949
Then in accordance with the line of answers so far...
It could be Ur turn signal oil is low in the right rear...
Old Jul 18, 2012 | 11:01 AM
DocRed's Avatar
DocRed
Seriously guys..no need to be a$$holes. He is in dire need of a solution. Ignore those guys, all you need to do is switch to syn3.
RidemyEVO
EVO
13
Jan 12, 2011 07:47 PM
Charlie Harlie
Exhaust System Topics
Aug 4, 2010 03:29 AM
Cazimere
Jul 25, 2010 02:29 PM
kmallein
May 27, 2007 08:41 AM
Jameson
Mar 13, 2007 06:37 PM
