Cold Blooded!
Old Jul 18, 2012 | 10:58 PM
Mark_H's Avatar
Mark_H
Sounds like you may be running lean to me. Check them plugs. If there white your lean.
As others have said you can't just jump on an EVO and ride. I always wait until the heads feel warm to the touch. usually about 2-3 minutes for me. I usually need the choke for about 20-30 seconds and then it will idle on its own in the summer. Winter I do 20-30 sec's of choke and then have to keep her running by throttle. Warm up time depends on temp but like I said earlier, when the heads are warm to the touch I ride, not before.
Old Jul 18, 2012 | 11:19 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
The carbed bikes came from the factory very lean.
I've changed the main jet on my wife's '99 and I Dyno-Jetted my '98.
Another consideration would be to check or replace the intake gaskets just in case they're sucking extra air.
Old Jul 18, 2012 | 11:38 PM
pdog's Avatar
pdog
My buddies sporty was the same way. I pulled the bowl and got the slow jet out took it to dealer got the next one up problem gone. Just a thought.
Old Jul 19, 2012 | 04:18 PM
jimbo285's Avatar
jimbo285
Checked plugs, they were white/grey at tip and electrode, sooty on threads. Confusing reading to me. I also think after reading these and other comments that i'm lean. Time to run to the store for jets. Should I replace air/fuel mix screw and o-ring while I'm at it?
Old Jul 20, 2012 | 12:46 AM
jimbo285's Avatar
jimbo285
Forgot to mention PO installed a Mikuni carb. I ran the idle mix screw and it was at 2 turns out. I ran it in till idled down, and ran it out till idled down, split the difference and now I'm out about 3 turns. Does anybody think that will make a difference? Havent ridden yet due to torrential rains here.
Old Aug 7, 2012 | 09:17 PM
Scudda's Avatar
Scudda
I'm glad I found this thread I was going to post a similar question...I have a 95 fxdl..stock motor except for V&H short shots..and a kuryakin mach 2 air cleaner. I had the bike tuned on a dyno. I believe they put in a 45 pilot jet and a 180 main and 2 shims on the needle. I have the dyno sheet and the air fuel is right on. But I have noticed ( even before the work) that the bike is very cold blooded. I need to let her warm up with the throttle lock for a few minutes and the ride it for a few blocks or she will stall cold..even on days like today after I have ridden for a while. If I let the bike sit for a few hours same issue. But after it warms up she runs like a bat out of hell with no stalls.....so I'm guessing I really don't have an issue. If I'm wrong please let me know.
Old Aug 7, 2012 | 10:23 PM
jimbo285's Avatar
jimbo285
Since I payed attention to what everyone said about choke for 15 seconds and then throttle locking idle for a couple of minutes, I havent had any problems. I ride away when the rockers are warm to touch and it doesn't pop or snarl at all. Definatly barks though! It was just a sharp learning curve for me to negotiate.
Old Aug 7, 2012 | 11:48 PM
02hdfxst's Avatar
02hdfxst
My 02 is very cold blooded. It takes quite a while for full warm up. But after its warm it runs absolutely perfect. Unfortunately the PO's son who sold me the bike after his father passed away has no idea what was done to the motor. But I believe there's quite a bit of work done that I still have no idea about. I only choke it enough to start then just give some gentle throttle till warm. It works.
msulli
Exhaust System Topics
Oct 19, 2021 02:44 PM
IRON1250
EVO
39
Oct 14, 2021 12:37 AM
tar_snake
EVO
14
Sep 4, 2018 10:52 AM
frbeall
Carburetor Related
Mar 5, 2011 06:37 AM
TestFlyer
May 7, 2007 10:59 PM
