Stock Mini Apes (rolling them forward?)
Old Jul 20, 2012 | 11:36 AM
ghoticov's Avatar
ghoticov
Originally Posted by ghostrider69
Torque wrench? I've never used a torque wrench on anything but internal engine parts. Been doing it like that for over 25 years and have never had a problem. But, you never know.
My problem is I usually over tighten things and I don't want to snap a bolt. I like the "turn em til their tight" method but I know myself and it never seems tight enough so I keep going and going until POP, broke screw.
Old Jul 20, 2012 | 04:47 PM
jreichart's Avatar
jreichart
A 3/8" torque wrench wil get you through 90% of what you need to do on the scoot. A 1/2" is good to have for the larger fasteners like steering head nut etc, but won't get used very often for anything else. An inch lb wrench is also helpful for all the cover bolts, but for most things you can convert the inch lbs to ft lbs. I think the riser cap is 20-25 ft lbs, but don't quote me on that. I'll check my manual tonight and let ya know.
Old Jul 20, 2012 | 04:58 PM
redheadfred's Avatar
redheadfred
Not a real good pic , I'll try to take another to give you a better idea
Old Jul 20, 2012 | 05:03 PM
Trey Hogger's Avatar
Trey Hogger
For the handlebar clamp screws - 12-15 ft lbs.
Old Jul 20, 2012 | 05:12 PM
ghoticov's Avatar
ghoticov
I think I read that it is 12-15 ft lbs.... and of course, I go to Lowe's and the only 3/8" torque wrench they have is a 20-100ft lb ones (so I bought it). Ugh. lol
Old Jul 20, 2012 | 05:13 PM
ghoticov's Avatar
ghoticov
Could you take one with the handle bars straight? Its hard to tell how they look because of the wheel being turned.
Nice looking scoot though!
Old Jul 20, 2012 | 05:14 PM
ghoticov's Avatar
ghoticov
Thanks, I actually just read that. I did a google search for it. I bought one from Lowe's but its a 20-100 ft lbs wrench. Wondering if I can use it anyway.
Old Jul 20, 2012 | 05:35 PM
jreichart's Avatar
jreichart
IMO, an extra 5 ft/lbs isn't going to make much difference.
Old Jul 20, 2012 | 06:07 PM
ghoticov's Avatar
ghoticov
Ok cool. Truthfully I probably would or could tighten them tighter than 15 ft/lbs by hand. It will be interesting for me to feel how tight that is with a torque wrench.
Old Jul 21, 2012 | 01:06 AM
CSS_FXD's Avatar
CSS_FXD
Yeah dude just loosen the four clamp bolts up some and push the bars forward to where you like them simple stuff. Then tighten the bolts up in a criss cross patern like. You can also pull one bolt out at a time and put a dab of blue lock tight on the threads for peace of mind just don't use the red stuff it's damn near permanent the blue is not and comes out with a wrench just fine. I use that blue stuff on alot of my bolts. Have fun the bike will look a lot better when your done. I will put mine forward when I put my new Santee 12" on my train soon.
