Brake light hard to activate
Old Jul 23, 2012 | 09:55 PM
Wakko47's Avatar
Wakko47
Default Brake light hard to activate
'95 Heritage, both front and rear, brake light doesn't come on until the pedal or lever are activated pretty hard. For someone that likes to tap the brakes just to pop the lights, it's rather inconvenient. Any adjustment or way to fix that, or is that "how it is"?
Old Jul 23, 2012 | 11:37 PM
Fatbob usmc EOD's Avatar
Fatbob usmc EOD
Take a look at the switch. I'm thinking it shouldn't be that hard to activate. The switch might be bent requiring you to press harder on the pedal. Other then the switch being bent you might have to fab on an extension if you want it to activate with less pressure/ travel.
Old Jul 24, 2012 | 12:30 AM
leeboy685's Avatar
leeboy685
did you touch the housing at all? adjust it, put a screwdriver to it, move anything? the switches arent complicated, just sensative.
Old Jul 24, 2012 | 06:35 AM
Wakko47's Avatar
Wakko47
I'm not even sure where the rear switch is. Just got the bike Sunday.
Old Jul 24, 2012 | 12:41 PM
leeboy685's Avatar
leeboy685
front and rear may be one and the same, if so, it's most likely on the handle bar next to the throttle.
Old Jul 24, 2012 | 12:44 PM
Wakko47's Avatar
Wakko47
How would that work then? Doesn't seem right in my mind.
newmanb138
2014-2024 Touring Models
Apr 27, 2017 08:15 AM
Richy8302
EVO
Aug 18, 2014 08:50 PM
ruckus4offroad
Mar 23, 2014 08:59 PM
cweiss
Aug 17, 2013 07:59 PM
frenchbiker
Oct 26, 2011 05:25 PM
