Convert Evo solid motor mounts to rubber
Old Jul 30, 2012 | 11:49 AM
oct1949's Avatar
oct1949
Read, look or post in here to help ya.
https://www.hdforums.com/forum/evo-classic-models-84/
Old Jul 31, 2012 | 07:13 PM
cjdock's Avatar
cjdock
Good link with a ton of good stuff, thanks!
Old Sep 14, 2019 | 04:49 PM
SPITZEGESCHOSSE's Avatar
SPITZEGESCHOSSE
I had a Suzuki Boulevard that made my hands numb on two hour ride. ☹️ I’ve since gave that bike to a buddy of mine and acquired 3 Harley’s. An 05 sporty. Rubber mounts. An 08 heritage softail solid mounted and an 1996 ultra classic electraglide rubber mounts. None of them make my hands numb. The Electra vibes my vision a bit sometimes at certain speed though. ?? ☹️ I’m puttin a new tire on it in a few days and I just drilled out the pissy little centre in the mufflers and it seems to vibe less already ? Buddy that I gave the Suzuki to says it vibes less with his new Vance Hines I’m thinkin restrictive exhaust can cause Te engine to hit a little harder ? The heritage has V and H straight shots on her and I live ridin it at any speed A lot of factors can change the ride that’s for certain. Don’t give up on it yet good luck 👍
Old Mar 24, 2020 | 04:12 PM
Rusty E Good's Avatar
Rusty E Good
What the heck are fluid balancers? Never heard of them
Old Mar 24, 2020 | 06:25 PM
Since 1968's Avatar
Since 1968
A company called Tom Hayden used to make them, maybe still do. I installed a set on my '91 softail years ago. It's essentially a round tube partly filled with a liquid or possibly small metal *****. You install one on your compensator sprocket and one on your clutch basket. They should work just like the balancing beads that have become popular for balancing tires. The internal media gets flung around in such a way that vibration amplitude is reduced. In my experience it helped some, but it was not a night and day solution. I'd suggest if anybody is having a real hard time with vibrations on their Evo, get a look at the polymer iso parts that connect your handlebar risers to the front end and see if they are set up correctly and in good condition. Also double check all motor and tranny mounting bolts for tightness as mentioned above. My son bought mine and eventually geared it taller which was very helpful. It was making plenty of torque to pull the taller gears, you'd hardly know the difference. I believe he used a 'European spec' rear sprocket, can't say the tooth count for sure but something like going down from 70 to 61.... This forced the installation of a new belt due to length needed.
Old Mar 24, 2020 | 07:02 PM
Rusty E Good
Thanks for the fast as hell reply. I was curious for my 96” stroker shovelhead. Even balanced and geared taller the notorious vibrations are present. My 87 Electra cracked the right side case last fall. Had 93,000 plus miles on her. A buddy welded the aluminum case and I had flywheels rebalanced so that bike is actually real smooth now That old hag of a bike is roughly 93” power and torque wise. Stock stroke parted heads and a few other goodies. No need for a ugly new hd when I got 2 classics. Thanks for reply
89FLHTC
EVO
29
Apr 29, 2016 05:37 PM
lakedrum03
Jan 2, 2016 10:23 AM
jhmp
Jan 2, 2008 08:32 PM
89 FXRS
EVO
14
Dec 17, 2007 12:48 PM
Rocket350
Sep 7, 2007 07:34 AM
