Handlebars ... shoot it to me straight :)
Old Aug 23, 2012 | 08:54 PM
  #31
ghoticov's Avatar
ghoticov
Originally Posted by CSS_FXD
Internally wiring is easy to do. Strip off the stock plastic tubing off the wires then get some shrink wrap tubing to cover your wires with. I ran a piece of heavy gauge wire thru the bars then taped the wires to the end of the lead wire then pulled them thru easy stuff.
Why would i need to strip the wires and then shrink them back together? Cant I just unplug them at the wire harness and run them through thag way? Maybe you were thinking I was going to have to go with longer wires? I am trying to stay at the same height bars (or drill holes in my stock bars) and run those internally.
Old Aug 23, 2012 | 08:57 PM
  #32
ghoticov's Avatar
ghoticov
OH and maybe it was said already but for sure disconnect your file line at your tank or you will snap the line at he injector like I did . And be sure to put a towel down on your felt rocker box or your cross over fuel line connector will scratch the hell out of your chrome when you slide your tank back another hard lesso n learned
Yea, I did know I needed to disconnect the fuel line....I just need to google or youtube it to see how to do it. Also, good call on protecting the chrome... I would not have thought about that. Lol
Old Aug 23, 2012 | 09:35 PM
  #33
soft 02's Avatar
soft 02
If your not changing the bar hight then leave the wires alone.
Old Aug 23, 2012 | 09:36 PM
  #34
soft 02's Avatar
soft 02
suggest adding an inch to the cross over line incase you want to do a tank lift down the road.
Old Aug 23, 2012 | 10:07 PM
  #35
ghoticov's Avatar
ghoticov
Ok,... I figured he thought I was going to go higher. I have thought about it but I think the 12" height feels pretty good and I am probably going to stay with my stock bars for now and try to figure out a way to drill holes to run the wires.
Old Aug 23, 2012 | 10:11 PM
  #36
ghoticov's Avatar
ghoticov
I won't be doing a tank lift, just not crazy about the way it looks.
I am still debating on getting those 12" Wild 1 Outlawz. I could use my current cables and just move everything over to the new bars. I wouldnt even need to undo the clutch or throttle cables would I? Juwt leaven them connected to the switch box or whatever. Shouldn't I just be able to unplug the wires at the harness and run them through the bars, then connect my switches and that's it?
Old Aug 23, 2012 | 10:14 PM
  #37
soft 02's Avatar
soft 02
As long as they are the same hight and width.
Old Aug 23, 2012 | 10:27 PM
  #38
ghoticov's Avatar
ghoticov
Yikes, I didn't think about the width...I will have to see how that is measured and see.
Old Aug 23, 2012 | 10:34 PM
  #39
ffd136's Avatar
ffd136
If you buy new handle bars I will gladly buy your stockers for the right price!
Old Aug 23, 2012 | 10:44 PM
  #40
ghoticov's Avatar
ghoticov
What's the right price?
