Cam cover torque specs
Old Jan 22, 2007 | 08:00 PM
*JC*'s Avatar
*JC*
Default Cam cover torque specs
I'm sure this question has been asked a billion times and I did a search but couldn't find the answer... So, please excuse me.
I'm about to change my stock cam cover for a chrome one and I need to find out the torque specs for the cam cover bolts... (No, not talking about the timing cover.)
Do I need to remove the forwardexhaust? I have the after market Hooker "Trouble makers"... So I wasn't sure if maybe there was enough clearance since it's not the stock exhaust?
Thanks for your help.
Old Jan 22, 2007 | 09:41 PM
DaveJ's Avatar
DaveJ
Default RE: Cam cover torque specs
According to the service manual, which I happen to have sitting next to me, they should be tightened to 125-155 in-lbs or 14.1-17.5 nm. However, the manual also calls out for a sequence in which the screws should be tightened. Starting at the top left and going clockwise, here is the order: 1, 7, 6, 4, 10, 8, 2, 3, 5, 9.
[align=left] [/align]
Old Jan 22, 2007 | 09:43 PM
chester1957's Avatar
chester1957
There is a special tightening sequence, I would take $50.00 and buy a manual. Lotsa good stuff in there. Many parts have special little things about them. BTW 125-155 in-lbs.
Old Jan 22, 2007 | 10:03 PM
DaveJ's Avatar
DaveJ
ORIGINAL: chester1957
Ditto.
Old Jan 23, 2007 | 02:01 AM
JLOCKHART29's Avatar
JLOCKHART29
Be sure and torque to the low side of spec. and make sure holes are clean of oil before inserting bolts. Don't want to split bolt holes.
Old Jan 23, 2007 | 08:06 AM
*JC*'s Avatar
*JC*
Hey, thanks everyone, very appreciative...
Yea, been meaning to buy one of those manuals...
Old Feb 15, 2024 | 06:55 AM
Eric S's Avatar
Eric S
Stage I
Default Low side of torque specs.
I was wondering why it is important to tighten the bolts to the low side of the specs. I just changed all of the bolts on my evo 88 cam cover and tightened them to the maximum. Should I take them out and re-torque them? If so, why?
Old Feb 15, 2024 | 07:21 AM
Rounders's Avatar
Rounders
There has been talk about the cam plate and cam cover specs being a little high. I am not sure what exactly the current consensus is.
Make sure those holes are clean and dry. The concern is oil getting hot and expanding. I wouldn't own a harley without own a manual for it.
Old Feb 15, 2024 | 08:54 AM
djl's Avatar
djl
The fasteners at the positioning dowels have been know to strip which is why torquing to the low end of the spec is recommended; 130 in.lb. should do it. No need to take them out and re-torque. The more times those fasteners are R/Rd, the more likely for stripping. Back in the day on the Twin Cams, many replaced the questionable fastener with studs.
Old Feb 15, 2024 | 09:34 AM
hattitude's Avatar
hattitude
I always change the cam plate dowel screws to studs whenever I remove a cam plate. I never had an issue with cam chest cover bolts... I might just be lucky..
Their can be quite a debate on the torque spec range. I have heard different arguments about what it stands for, how to interpret it, and how to use it.
For my part, I have a set of expensive, very good quality torque wrenches that all came with calibration certificates. But I rarely retest them. Even their calibration cards show a plus/minus factor to their accuracy.
I always chase (clean) all threads on anything I disassemble, before reassembly. I start with clean, dry fasteners and thread holes.
On clean, dry fasteners, I always shoot for just below the top spec. (ie: top spec 120, I set torque wrench at 115)
If they call for lock-tite, I will usually go mid spec.
If they call for anti-seize,, I will reduce the max torque by 25%
On critical torque applications like head bolts, I will follow the manual's (or for non-OEM head gaskets, the gasket maker's) recommendations exactly. This include thread prep, torque progression, and/or finishing angles if applicable.
As much as I am a proponent of proper torque, I do not torque my oil/trans/primary drain plugs. I had a friend strip one with a torque wrench. While I was not present to see what/how he did that, it was a pain to fix... now I use good old fashion "feel" for those.
An interesting note:
My '01 & '03 Softail, as well as my '12 Touring Factory Service Manuals call for the cam cover screw torque as 90-120 in. lbs.
Yet my '16 Touring and '16 Dyna Factory Service Manuals call for the cam cover screw torque as 125-155 in. lbs.
I believe they are the same fasteners, same threads, same gaskets....I never before noticed, nor heard why, there was a change...
