Gas light always on
Old Sep 5, 2012 | 07:37 AM
Ground Shaker's Avatar
Ground Shaker
Default Gas light always on
I have an 06 train that i purchassed about 2 years ago. Love it!!! But the damn gas light has always been on since I got it. Anyone ever had this issue???
Old Sep 5, 2012 | 09:14 AM
magna's Avatar
magna
Yeah I get it on occasions along with the needle on the gauge showing empty, usually after I've filled up, sorts itself out after 2 or3 miles though, you've probably got a loose connection somewhere if the lights staying on.
Old Sep 5, 2012 | 09:58 AM
purpledeuce's Avatar
purpledeuce
Sounds like your float is stuck inside the tank. Just use the odometer
Old Sep 5, 2012 | 10:04 AM
Ground Shaker
I'm fine with using th odometer but i'm sick of having tha damn light on
Old Sep 5, 2012 | 10:24 AM
purpledeuce
Check the manual, see if there's a fuse you can pull
Old Sep 5, 2012 | 06:41 PM
lupus's Avatar
lupus
This is what I was thinking too.
Old Sep 5, 2012 | 07:10 PM
Cygnusx51's Avatar
Cygnusx51
If you have the flush mount led fuel gauge, there is a bypass wire (usually grey) that is hooked up so that light will stay off. Check the connection of that wire, I had mine come loose before. You'll find it right under the tank where the fuel gauge wires are.
Old Sep 5, 2012 | 07:17 PM
Bikeswainsmate's Avatar
Bikeswainsmate
Why don't you just put gas in it?? lol
Old Sep 5, 2012 | 07:18 PM
Bikeswainsmate
Just Kidding!!!
Old Sep 5, 2012 | 07:31 PM
Ground Shaker
Sweet. I'll check that connection. I do have le LED flush mount gauge but even before I changed it the damn light was still alwaysm on. I'll check it out and let u know.
Iron lHorse
May 10, 2015 07:53 AM
Pdfisherman
Jun 1, 2013 04:22 PM
jasfromnz
Jul 7, 2012 07:37 PM
Keener
Jun 21, 2010 09:50 AM
jdsmitty10
Jun 10, 2009 08:14 PM
