Program security system
Old Sep 10, 2012 | 08:56 PM
rickoshea45's Avatar
rickoshea45
Stage III
Default Program security system
Hey guys,
I have a 2012 FLSTN, I would like to reprogram the security system to use my own code if the fobs ever failed by using the turn signals.
Every tutorial online does not seem to work so far, I figured maybe someone
here could help me out.
Old Sep 10, 2012 | 10:45 PM
Bluraven's Avatar
Bluraven
I'm not sure they are the same, but for my 09 Heritage:
To program a PIN-
1) Select a 5 digit (1-9) PIN
2) With an assigned fob present, turn IGN Key: IGN-OFF-IGN-OFF-IGN
3) Press left turn signal switch 3 times
4) Press right turn signal 1 time (turn signals flash 3 times). Current PIN will appear on the odometer. The first digit will be flashing.
5) Enter first digit of new PIN by pressing left turn signal switch the number of times of the number. For example if the first digit is a "3", then press the left turn signal three times.
6) Press the right turn signal switch 1 time to advance to the next number.
7) repeat step 5 and 6 for the rest of the 5 digit PIN.
8) After the 5th digit is entered turn ignition off, the odometer will return to normal and the new PIN will be stored.
To disarm by PIN-
1) Turn to Ignition
2) Within 2 seconds hold both turn signal switches in until the "key" icon on the odometer flashes.
3) Enter the first digit of the PIN by pressing the left turn signal the number of times of the PIN number. For example if the first digit of the PIN is "3", then press the left turn signal three times.
4) Press the right turn signal 1 time to advance to the next PIN digit.
5) Repeat steps 3 and 4 for the remaining 4 digits of the PIN.
Don't forget to press the right turn signal switch after the fifth digit is entered.
Your alarm is now disabled and will remain disabled until your fob comes within arming distance.
Hopefully this helps
Old Sep 10, 2012 | 11:56 PM
NDBadlands4-2's Avatar
NDBadlands4-2
Something else that may help. The engine kill switch must be set too off, and the system must not be activated when trying to set the system. (Make sure that the lights are not flashing when trying to do all the steps mentioned in the previous post)
Old Sep 11, 2012 | 08:02 AM
BARACU's Avatar
BARACU
Big Kahuna HDF Member
To program a PIN-
To disarm by PIN-
1) Turn to Ignition
The procedure for the 2012 is different than the 2009.....pg 72 in the owners manual...
Here's the instructions for my 2012. Should be the same
Off/Run switch to.... OFF
Ign switch to... IGN
Off/Run switch....RUN - OFF -RUN - OFF- RUN
Press left turn.... 2X
Press right turn ...1X
Enter 1st digit of new PIN by pressing and releasing left turn signal til number appears
Press rt turn signal 1 time and release
Continue thru all digits
Turn Off/Run switch to OFF....then turn IGN to OFF
Old Sep 11, 2012 | 10:41 AM
yzergod's Avatar
yzergod
Once you get it reprogrammed, practice, practice, practice. From experience, it sucks screwing around with this when you leave your key fob on the workbench end up having to put in the code!
Scudda
Feb 9, 2020 10:53 PM
jimjim
Mar 30, 2017 03:40 PM
Itay Frishman
Nov 9, 2014 06:54 AM
dustin1014
Jan 4, 2014 03:09 AM
kodak86
Aug 8, 2013 07:29 AM
