Night TRain rim question
Old Sep 14, 2012 | 05:12 PM
2XNightTrain's Avatar
2XNightTrain
Default Night TRain rim question
I'd like to get this accomplished without a dealer, but what is the widest rim (front) and tire I can put on a Night Train after removing the fender? Also without modifying anything else involved?
Old Sep 14, 2012 | 05:24 PM
jreichart's Avatar
jreichart
On the front or rear? On the front I'm running a 16x3 rim with a 150/60/16 Metz. Plan on upgrading to a 160 Metz next change. You might be able to fit a 180 , but without measuring I couldn't be sure.
Old Sep 14, 2012 | 08:39 PM
2XNightTrain
On the front only. Did you have to have different bearings or anything added?
Old Sep 15, 2012 | 03:25 AM
jreichart's Avatar
jreichart
I had to do some work only because I used a rear wheel on the front. Even so, it was only a matter of having about 1/8" milled off the brake side hub, and running a rear brake rotor and hardware. Reused stock spacers and everything lines up great. If you were to get a front wheel that was built for your bike, you shouldn't have any issues at all. Good luck and post up some pics of the new mods!
Cmcbay
Mar 23, 2017 12:10 PM
Joeynotz
May 19, 2016 04:36 PM
antichrome90
Nov 21, 2014 09:29 AM
CountryPunk
Sep 28, 2009 07:06 AM
cbaker
Jun 20, 2008 10:29 AM
