Slim air cleaner
Old Sep 19, 2012 | 09:52 PM
Archie01's Avatar
Archie01
2nd Gear
Originally Posted by DK Custom
The HiFlow 587 vents the hot oily air into the atmosphere via either the Breather Bolts that have dual mesh and dual foam filter inside the bolts.
(also available with the HiFlow 587 is the traditional hose and filter breather system)
The SE and the Ness BS both vent the hot oily air back into the engine via internal passageways built into their backplates. This is to satisfy the EPA, but it is NOT good for performance or for the engine.
Both the SE and the HiFlow 587 flow more air than your engine can use, so if you are happy with your tune right now, there is no need to change it when moving from the SE to the HiFlow.
Thanks Kevin, great info, wish I had known this before I bought my SE kit. The dark days are coming here in WA state so this will definitely be one of my winter mods. Anyone interested in an almost new SE Stage 1 intake kit...
Old Sep 19, 2012 | 10:10 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by goats
just out of curiosity is there a way to catch the oil coming out of the highflow or do we just wash the bike more often?
No oil is being fed into the HiFlow Air Cleaner, so there is nothing to drip out or catch.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Sep 19, 2012 | 10:16 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by HD711
Arlen Ness Big Sucker kit does this by eliminating the breathers all together?
If this is the case, why not just plug up the breather holes
on the SE AC ?
May be a bad idea, as nowhere to vent the crank.
How does ANess get away with those breather bolts?
Anyone done this?
The bolts on the Ness BS have a passageway in them that empties out into the backplate, venting the hot oily air into the air cleaner.
Do NOT put solid bolts in your breather vent on the head. The engine must vent. If you plug those holes it will vent via blowing out a gasket.
Old Sep 19, 2012 | 10:18 PM
soft 02's Avatar
soft 02
Hmm. Do you have a bolt kit for the ness that has the brass filters in them?
Old Sep 20, 2012 | 10:22 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Not for the twinkies...only have the longer bolts for Sportsters and Evo's.
Old Nov 11, 2013 | 05:11 PM
joebfrank1's Avatar
joebfrank1
Stage III
What is your opinion on the Roland Sands Design - Venturi Air Cleaner Speed 7 - Contrast Cut? Link: http://www.rolandsands.com/products/...7-Contrast-Cut
Old Nov 11, 2013 | 08:41 PM
goats's Avatar
goats
It is a compressed brass bead filter. Only air passes through it. I imagine that if you never washed your bike you might see a bit of residue. That style of breather has been used for many years in other applications. First time Ive seen it on a bike. Great idea!
really? i thought it was just mesh and some foam... next time i think about it i will have to take mine apart.
haha, just noticed the date on this
Old Nov 11, 2013 | 08:44 PM
soft 02's Avatar
soft 02
You are correct. At work I use the compressed bead type but you are correct. Just a screen and foam. I posted before having one in hand.
Old Nov 12, 2013 | 01:54 AM
BMM48's Avatar
BMM48
You will see a few of these on Slim's in the "Show us your Slim" thread. They are a good performing AC and in my opinion look the goods.
jb27
Jul 2, 2013 12:08 PM
jb27
Jun 29, 2013 06:46 AM
santajim
Jul 22, 2011 11:07 PM
Mrawsome21
Sep 9, 2009 07:05 AM
txoval
Mar 7, 2009 01:27 PM
