tank bolt won't budge help!
Old Oct 8, 2012 | 04:59 PM
cmosentine's Avatar
cmosentine
Put some anti-seize on it to avoid the same problem in the future.
Old Oct 8, 2012 | 07:00 PM
Jim Kraft's Avatar
Jim Kraft
If it had loctite on it a heat gun would have helped also. With a good heat gun you can localize the heat pretty well. Heat almost always works for me. If it has red Loctite, heat is the only way.
Old Oct 9, 2012 | 08:21 PM
marines267's Avatar
marines267
Originally Posted by rgjujitsu
So I'm trying to remove my tank bolt that is near the seat so i can slide tank back but this thing will not budge. It's a t40, i tried screwdriver nothing, wrench nothing, neighbor brought over breaker bar still nothing? I'm a big strong dude and this thing will not move. Any advice?
Impact either the air type or the manual that you hit with a hammer
Old Oct 10, 2012 | 01:01 PM
HDFatboy98's Avatar
HDFatboy98
I've never tried it but I've heard equal parts of acetone and atf is the best when needing to break bolts loose
grumpy56
Jul 2, 2016 03:11 PM
dave713
Jul 7, 2013 01:58 PM
Iron Butt Springer
May 9, 2012 08:57 PM
klf33
May 21, 2008 12:25 PM
swomack
Nov 16, 2006 12:44 AM
