Shorter Windshield Questions/Suggestions
Old Oct 11, 2012 | 10:18 PM
megabutter's Avatar
megabutter
Alright! Thanks for all the info so far guys!!
So, if I decide to cut mine down, Rich, do you have a tutorial you'd recommend? I was hesitant at first mention of that, because of getting it to look as good as the factory.
The lip area might be the way to go.
I need to go down to the garage for a few measurements straight away!
Old Oct 12, 2012 | 10:37 PM
megabutter's Avatar
megabutter
I found some great tutorials. Hope to cut mine down this weekend.
Old Oct 12, 2012 | 11:57 PM
soft 02's Avatar
soft 02
Take pictures for those who havnt done it.
Old Oct 13, 2012 | 12:52 AM
PanHeadRich's Avatar
PanHeadRich
Sorry I missed your question. In case you'd still like some tips: Just put blue painters tape on both sides of the plexi, draw your new radius line, drill a hole in the center of that line that a saber saw blade can fit into and cut using a fine metal blade from the center, to each side. Use a hard sanding block with 400 grit sand paper to smooth out any uneven waves of the edge. Then put a nice smooth finished edge to the plexi by sanding that edge again with the block and 2000 grit. It will look better than the stock edge. It's actually pretty simple as long as you cut cut a smooth line. If in doubt, practice on some plywood first
greenhell
Aug 26, 2014 09:40 PM
tpcowfish
2014-2024 Touring Models
18
Jun 10, 2014 08:55 AM
frozensoul
Mar 9, 2014 11:09 PM
tibadoe
Mar 9, 2010 06:52 PM
rdking
Jul 15, 2005 10:05 PM
