HID H4 conversion
Old Apr 12, 2013 | 11:25 AM
  #71
sp9997's Avatar
sp9997
Thanks Motown,
Looking at the wiring diagram the extra black and extra yellow are for future passing lamp add on if required. I am thinking I am going to get into the bundle near the triple tree make the splice on yellow (low beam) mount the switch on the tree cover and be done with it ... I am heading out to NAPA autoparts see if I can find a nice small sealed spdt switch or a small toggle switch... Thanks for warning me not to run without relay or switch ... will update on how it goes..
Old Apr 12, 2013 | 01:07 PM
  #72
Brusier1028's Avatar
Brusier1028
Not wanting to hijack but I think the phase 7 LED headlight is where it's at. Plug n play. No extra wiring or worry about heat or burn out.
Old Apr 12, 2013 | 03:31 PM
  #73
sp9997's Avatar
sp9997
Brusier there are lots and lots of folks who are running HID kits without issues. The light output over stock is significant. However looking at the phase 7 LED the price is out of my range. Phase 7 headlight is $299 vs. HID kit that cost me $29.99. I would rather to stick to my HID kit. The more I work on my bike the better I get to know her, that is how I see it... Appreciate the suggestion though ...
Old Apr 12, 2013 | 04:11 PM
  #74
1st 96 ultra's Avatar
1st 96 ultra
I bought this switch on e bay but is a Harley switch , worked out good but I wired it to the ground wire at the head light , NO ground , NO light
Old Apr 12, 2013 | 04:27 PM
  #75
jd8181's Avatar
jd8181
I also wired my switch into the ground.
A problem I might be having with my hid light (I and not sure if it is a problem yet or not since I have only riden once because of the weather) is mine I mounted in the oem 5 3/4 bucket and the bulb comes all the way out to the glass, so I think some of the light is going up and out of the top glass lense and missing the reflector. I will have to get the bike out at night and see what I think. Maybe that is why the tell you with a 5 3/4 light to use and adjure/bullet headlight??
Old Apr 12, 2013 | 06:59 PM
  #76
milesvdustin's Avatar
milesvdustin
So the linked eBay kit will have hi and lo beam function with the switch on the handlebar, both modes in HID?
Old Apr 12, 2013 | 07:04 PM
  #77
jd8181's Avatar
jd8181
Yes it has both hi and low. Both hid. Hid are only one element. When you switch to hi or low there is a magnet and the bulb moves back and forth adjusting the position of the bulb making it either hi or low
Old Apr 12, 2013 | 07:24 PM
  #78
milesvdustin
Oh sweet Lord this is awesome!!!! I ride a dyna so I think I'll mount a switch under the battery box or something like that. Splice it right into where the ground runs into the connector under the seat.
Old Apr 12, 2013 | 08:23 PM
  #79
rlowride's Avatar
rlowride
i run the sportiva kit from forte motors on my softail. its only 54 bucks shipped...it was a rather cumbersome kit... it was the plug and play mostly, it came with a relay already with it, that i had to run the power and ground wires back to the battery. it works perfect.. when i flip on ignition switch it all fires up.. with out the relay, the safety circuit would then shut it off... once i wired in the relay that came with the kit.. good to go... just like the regular headlight.. I was going to buy this kit here listed for my dads sportster, as I had a bit of trouble jamming everything in my headlight bucket.. this one here i thought may fit... but now i am a lil concerned...
Old Apr 12, 2013 | 08:37 PM
  #80
Elvira's Avatar
Elvira
I LOVE mine. Dollar for Dolla the best moeny I've spent on my scoot!
