Driving Lights and High Beam 02 Heritage
Old Oct 19, 2012 | 06:45 AM
davese's Avatar
davese
4th Gear
Default Driving Lights and High Beam 02 Heritage
Hey,
I searched this forum for "Driving Lights" and did not come up with an answer to this question. Hopefully someone here will help me.
I have a 02 Heritage and just bought new LED driving lamps and headlamp. I want to keep my driving lights on when my high beams are on. I am not wanting to know any legal BS about having them on or not.
Can anyone help me with what wire I need to do what with? I do not want to run one directly to the battery as I most likely forget to turn them off some sunny day and drain my battery.
Thanks for any help.
Old Oct 19, 2012 | 09:48 AM
hdgzr's Avatar
hdgzr
You might try this; the subject was adding fog lamps to existing lights on his Heritage...
"On my Heritage I run the relay on the same circuit as the passing lamps. The passing lamps power was moved from the headlamp low beam to its own feed from the ign switch on the center console. So now passing and fog lamps can be on for either high or low beam and there is no danger of overload."
Old Oct 19, 2012 | 12:04 PM
SoonerSoftail's Avatar
SoonerSoftail
There are drawings on the internet to do what hdgzr suggested or there is an plug in harness from HD to do it.
Old Oct 19, 2012 | 12:22 PM
2002FLSTCI's Avatar
2002FLSTCI
I bought the wire harnse adaptor from my local HD dealer. It was less than $20. Easy to put on. I now ride during the day with high beam on with the passing lights on also.
Prot
EVO
47
Sep 18, 2016 08:17 AM
overthehill?
Aug 20, 2014 12:08 PM
roblack
Sep 2, 2012 01:51 AM
bluelineman
Jul 23, 2012 11:17 PM
choo53
Apr 16, 2010 10:31 AM
