103B expected noise
Old Nov 5, 2012 | 02:25 AM
ShovelnTC's Avatar
ShovelnTC
Default 103B expected noise
Hi Guys,
I have a brand new total stock slim and after doing a few hundred miles I have found that there seems to be quite a lot of engine noise at certain times.
The noise sounds like valvetrain or wrist pin rattle but I'm really not sure and it is most apparent on mild load below 2000rpm.
At first I only noticed it intermittently and when I backed off and then opened it up again it sometimes disappeared but not always.
Today I did a couple of hours and it seemed to get worse as the ride went on but the day was also getting hotter so I expect heat is a factor.
When stopped and idling there is no signs of it.
My questions are,
Should I expect this level of rattle as normal?
Does the 103TC have knock sensors?
So am I worrying for nothing or does this sound like I should be getting it looked at.
As with a lot of these things it is only apparent at certain RPMs and load conditions so if the dealers tech just does the old around the block road test it will likely not show up and they'll just say all is good.
Any advise appreciated.
Mark.
Old Nov 5, 2012 | 04:37 AM
Blk and Chrome's Avatar
Blk and Chrome
Yes if you wear a helmet or have a windshield and stock exaust you will hear lots of noises.
Old Nov 5, 2012 | 06:30 AM
Rodzilla6's Avatar
Rodzilla6
I would have it checked and documented if it's more than normal...take it to an indept. mechanic first, then if not normal to HD. My brother had a brand new heritage that had a NOT NORMAL nock at times when warm (started at 900 miles...), similar to yours ( I was beside him several times...). HD took it apart 3 times, last time with SE parts and it is better, but NOT gone...he got a free extended warranty on the motor...does not make you feel warm and fuzzy though going on a trip...My rocker has the same motor, put them side by side and it is VERY OBVIOUS!! Good luck.
Old Nov 5, 2012 | 06:42 AM
eleft's Avatar
eleft
Primary chain rattle? Accelerate hard(in 1st or 2nd) and back off quickly when cold. The chain should auto adjust.
Al
chrisbratvoldjunk@gmail.com
May 23, 2017 11:33 AM
Gatorhog94
Jun 22, 2016 05:03 PM
Mike Lawless
Sep 26, 2015 08:40 PM
ohioflhs
General Topics/Tech Tips
23
Apr 13, 2015 08:43 AM
wingnut79
Exhaust System Topics
15
May 2, 2007 05:32 PM
