How much fork oil?
Old Nov 13, 2012 | 05:37 PM
tnhd06's Avatar
tnhd06
Default How much fork oil?
Changed my lowers to chrome today.. 06 flstc.. It went great but unsure how much oil to put in the forks... Manual (red book) says 12.9 ozs if fork were not taken apart. or 119.9 m/m or 4.5 in if they were? .. Who's the math guy out there that can tell me how many ounces to put in these forks?..I think I might need a little more than 12.9 since I took them apart and cleaned them..thanks
Old Nov 13, 2012 | 06:55 PM
tnhd06's Avatar
tnhd06
bump..
Old Nov 13, 2012 | 07:59 PM
jreichart's Avatar
jreichart
IIRC, this is the difference between the two methods:
If the forks are on the bike and assembled, or they cannot be held vertically plumb while filling, then use the ounces method.
If the forks are off the bike and assembled, but the springs are removed, then use the measurement method. The measurement given is the airspace from the top of tube to the top of oil with the springs removed and the shock fully extended and vertically plumb.
Both methods should result with 12.9 ozs of oil in each fork, but the measurement method is a bit more accurate and preferred if the shock is disassembled and off the bike. Otherwise, the ounce method is the only way to fill it.
At least that is the way it was described to me for my FX, don't know if the FL is any different.
Old Nov 13, 2012 | 08:44 PM
tnhd06's Avatar
tnhd06
Forks are off with springs out of them... Going to put 12.9 ozs of oil in them each and finish putting them together .. thanks
Old Nov 13, 2012 | 09:33 PM
20FXST06's Avatar
20FXST06
When I took mine apart and put them back together I used a little under 14 oz in each fork tube.
Old Nov 13, 2012 | 10:04 PM
jreichart's Avatar
jreichart
The spec for the FL is different due to the shorter tube length.
Old Nov 14, 2012 | 12:51 PM
oct1949's Avatar
oct1949
I don't remember how much is needed, but I know not all yrs take the same amount.
pgilbert689
Jun 30, 2018 07:30 PM
jimbo285
EVO
May 7, 2014 11:09 AM
psychocircus
Dec 30, 2011 12:40 AM
tuff
Jul 25, 2007 10:03 AM
whiplush
Oil Archive (no new posts)
Apr 12, 2005 07:46 PM
