Springer Problem?
Old Nov 25, 2012 | 06:59 PM
evade49's Avatar
evade49
Default Springer Problem?
i was looking at my bike today after a ride and i noticed the springer rockers hanging down(see pic) bike didn't ride or handle any differently but i was concerned because when i look at other classic springers i don't see their rockers hanging this low. what needs to be adjusted or fixed?
[IMG][/IMG]
Old Nov 25, 2012 | 07:59 PM
SprungDave's Avatar
SprungDave
To me it looks like your forks are fully compressed. I can not see that you have much, if any, travel left in your forks. Must be hell over rail road tracks.
I would jack up the bike to see what is binding. Or, if you bought the bike used, someone may have put "lowering" (read: shorter) springs onto the front end, resulting in the condition you now see.
If, when the bike is jacked up, the wheel (and rocker) lowers down to level with the ground (or pointed slightly downward), then the front end is not binding, so it is probably lowering springs installed. If the wheel can not move up an down, I would suspect that the bushings within the forks are bound up (either tightened too much and/or siezed due to lack of lubrication). Either way, you might need to rebuild the front end by replacing (or minimally lubing up) the bushings.
If it is due to lowering springs being installed, well, then you will just need to get a new set of stock-length springs and install. You may need to replace the shock as well.
Let me know what you discover after jacking the bike up.
Old Nov 25, 2012 | 08:02 PM
Scott Hall's Avatar
Scott Hall
That looks crazy! It looks like the shock and springs have collapsed.
Old Nov 26, 2012 | 03:44 PM
evade49's Avatar
evade49
Default lowering shocks
they must be lowering shocks because on the jack it all falls into place thanks for the info
Old Nov 26, 2012 | 04:32 PM
FLYING_BURRITO_BROTHER's Avatar
NOT A MODERATOR
KInda looks like an issue I had with my bones. The rockers were binding. I had serviced the sprigner 3very 2500 miles like you're supposed to also.
Old Nov 26, 2012 | 08:22 PM
F117ewo's Avatar
F117ewo
The shock doesn't support the front end, it only dampens the spring's upward and downward movement. It may be binding. Only way to tell is to remove one end of it and run it through its full range of motion. My bet is that it's something else in the front end that is all bound up though.
Jake
Cschmitt
Apr 30, 2020 10:28 AM
Babblewon
Nov 2, 2011 12:35 PM
No Skool
Oct 17, 2011 10:36 AM
marioz
Jul 23, 2011 11:41 AM
pwalsh1019
Aug 19, 2009 05:48 PM
