Problem with Vance & Hines Big Radius Exhaust
Old Jan 10, 2013 | 03:32 PM
2008 fatboy's Avatar
2008 fatboy
5th Gear
Unhappy Problem with Vance & Hines Big Radius Exhaust
Hi,
I wonder if anyone out there can help. I have just bought a second hand V&H Big Radius 2 into 2 ehaust for my 2008 fatboy problem is it does not have the screwed ports fitted for the oxygen sensors. Can these be welded on afterwards and if so where do i get the 18mm threaded stubs from?
Any help either with sourcing the stubs or better still finding someone to do it near Stoke-on-Trent England would be appreciated.
Old Jan 10, 2013 | 03:59 PM
Motown Strag's Avatar
Motown Strag
Originally Posted by 2008 fatboy
Hi,
http://www.mandmcycles.com/default.a...FYw-MgodPG0ALQ
or any shop that can order Drag Specialties parts.
Old Jan 10, 2013 | 04:04 PM
HD Pilot's Avatar
HD Pilot
Can't help on who to get the bungs welded by, but you can go to denniskirk.com and select from several choices of 18 mm O2 bungs.
Old Jan 10, 2013 | 04:25 PM
F22 Junky's Avatar
F22 Junky
I bought the exact same pipes with ecaxt same problem. Took off my rear O2 Sensor and took it to the local nut and bolt store. Bought 2 nuts that fit for $2. Took them and the new pipes (after marking where the nuts needed to be) down to the local welding shop. They charged $20 to TIG weld them in. TA-DA! O2 sensor ports!
Old Jan 10, 2013 | 05:14 PM
Motown Strag
Googled this...Stonefield Garage is an auto shop that does welding in your area.
01785 817 271 or email us at geoff@collierathome.fsnet.co.uk, or by using the online query form. Repairs in Staffordshire
Cant hurt to ask...
Old Jan 14, 2013 | 06:06 PM
2008 fatboy
5th Gear
Thank you to everyone that posted replies. After some research i managed to find a company on ebay doing stainless 18mm bungs at Ł4.00 each and they are based about 5 miles away from me also found local engineering firm that will tig weld them on. Without your help i wouldnt have known what to search for.
jcp0330
Sep 10, 2016 06:16 AM
Bennyg33
Jul 20, 2016 12:15 PM
11'heritage
Mar 6, 2014 07:51 PM
F22 Junky
Jul 14, 2012 08:07 PM
mplecha
Apr 6, 2009 07:22 AM
