Starter not engaging???
Old Jan 22, 2013 | 09:09 PM
brberk's Avatar
brberk
Default Starter not engaging???
I have an 02 Sofatil Heritage and I just got it started up today after a build up from an 88 to a 98 including head porting. Started and ran fine for the first two heat cycles then on the third cycle it would not start and then all of a sudden the starter motor just spun without engaging. Pulled the primary and the jsck shaft it throwing out into the clutch basket but is not turning it.
It is either the starter clutch, the starter relay or the curcuit breaker has burnedout. I put in new S&S compression release cams but the starter seemed to be struggling to turn it. Maybe I just need to install a new high-torque starter motor. And these starters are a BIT-- to remove. The oil bag and the back exhaust pipe both need to be removed.
Any suggestions out there??? Trying to save some work and/or money. . .
Old Jan 22, 2013 | 09:13 PM
snip0721's Avatar
snip0721
long ball allen sockets. no need to remove the oil tank then. tight but can be done. steve
Old Jan 22, 2013 | 09:16 PM
snip0721's Avatar
snip0721
get a good starter like an "all ballz". worth the money, and way better than the moco version....steve
HOGHIP
Apr 5, 2019 08:50 AM
Chummers
General Topics/Tech Tips
Aug 26, 2013 12:06 PM
Boat drinks
Feb 1, 2013 09:06 AM
andre747
Nov 9, 2011 05:11 PM
02glide
Oct 26, 2006 01:00 AM
